    Face Dimensions
    5 Posts 3 Posters 360 Views 3 Watching
      riteshrpatil
      I am having problems getting the length and breadth of a rectangular face in SketchUp. I am using this code:` def height
      fheight = 0
      bb = self.bounds
      	if bb.depth != 0
      		fheight = bb.depth
      	else
      		fheight = bb.height
      	return fheight.to_m
      	# Method to return the width of a face in m
      def width
      	fwidth = 0
      	bb = self.bounds
      	if bb.depth != 0
      		fwidth = Math.sqrt((bb.width)**2 + (bb.height)**2)
      	else
      		fwidth = bb.width
      	return fwidth.to_m
      end`
      But I am not getting the correct dimensions of the red rectangular face in attached screenshots.
        You're using bounds to get dimensions - BoundingBox objects are always aligned the the world axis. What you want to do is investigate the faces edges and their lengths. Sketchup::Edge got a length method that returns the dimension for the edge.
        btw
        <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;Method&nbsp;to&nbsp;return&nbsp;the&nbsp;width&nbsp;of&nbsp;a&nbsp;face&nbsp;in&nbsp;m<br /></span><span class="syntaxdefault">def&nbsp;width<br />&nbsp;&nbsp;fwidth&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">0<br />&nbsp;&nbsp;bb&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bounds<br /></span>
        You're extending the base Sketchup::Face class? If you do, beware that if you public the plugin you might run into naming conflict if some other plugin use the same name. Using the base classes has the same risks of naming conflict as making methods in the global namespace.
        • honoluludesktopH Offline
          honoluludesktop
          Same component, different bbox. The bbox is subject to the world axis at the time the component is created.
            <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;Returns&nbsp;nil&nbsp;if&nbsp;the&nbsp;face&nbsp;is&nbsp;not&nbsp;a&nbsp;parallelogram.<br />#&nbsp;Returns&nbsp;an&nbsp;array&nbsp;[width,&nbsp;height]&nbsp;on&nbsp;success.<br /></span><span class="syntaxdefault">def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_rectangle_size</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">outer_loop</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges<br />&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxdefault">nil&nbsp;unless&nbsp;edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">size&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">4<br />&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxdefault">nil&nbsp;unless&nbsp;edges</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">length&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">length<br />&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxdefault">nil&nbsp;unless&nbsp;edges</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">length&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">length<br />&nbsp;&nbsp;</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">end<br /></span>
            Untested - but I think it should work.
              As requested per PM:
              <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;Returns&nbsp;nil&nbsp;if&nbsp;the&nbsp;face&nbsp;is&nbsp;not&nbsp;a&nbsp;circle.<br />#&nbsp;Returns&nbsp;the&nbsp;radius&nbsp;on&nbsp;success.<br /></span><span class="syntaxdefault">def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_circle_radius</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">outer_loop</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges<br />&nbsp;&nbsp;edge&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">nil&nbsp;unless&nbsp;edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">curve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ArcCurve&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">curve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">radius<br />end<br /></span>
              <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;Returns&nbsp;nil&nbsp;if&nbsp;the&nbsp;face&nbsp;is&nbsp;not&nbsp;a&nbsp;semi&nbsp;circle.<br />#&nbsp;(ArcCurve&nbsp;and&nbsp;one&nbsp;edge&nbsp;connecting&nbsp;each&nbsp;curve&nbsp;end)<br />#&nbsp;Returns&nbsp;the&nbsp;radius&nbsp;on&nbsp;success.<br /></span><span class="syntaxdefault">def&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_semicircle_radius</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">outer_loop</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges<br />&nbsp;&nbsp;curve_edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">curve</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ArcCurve&nbsp;</span><span class="syntaxkeyword">)&nbsp;}<br />&nbsp;&nbsp;</span><span class="syntaxdefault">curve&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">curve_edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">first</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">curve<br />&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxdefault">nil&nbsp;unless&nbsp;curve_edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">all</span><span class="syntaxkeyword">?&nbsp;{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">curve&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxdefault">curve&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;</span><span class="syntaxdefault">edge&nbsp;</span><span class="syntaxkeyword">=&nbsp;(</span><span class="syntaxdefault">edges&nbsp;</span><span class="syntaxkeyword">-&nbsp;</span><span class="syntaxdefault">curve_edges</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">first<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;At&nbsp;this&nbsp;point&nbsp;you&nbsp;have&nbsp;all&nbsp;the&nbsp;data;<br />&nbsp;&nbsp;#&nbsp;curve&nbsp;refers&nbsp;to&nbsp;the&nbsp;ArcCurve&nbsp;of&nbsp;the&nbsp;semicircle<br />&nbsp;&nbsp;#&nbsp;edge&nbsp;refers&nbsp;to&nbsp;the&nbsp;Edge&nbsp;connecting&nbsp;the&nbsp;ArcCurve's&nbsp;ends<br /></span><span class="syntaxdefault">end<br /></span>
