    Disable OnLButtonUp when onLButtonDoubleClick
    10 Posts 4 Posters 979 Views 4 Watching
      c.plassais
      In class Tool, Is it possible to disable the method OnLButtonUp or OnLButtonDown when you call the method onLButtonDoubleClick
      Thank you in advance for your answers
      ChrisP
        Jim
        I do not think so. You can use a timer to defer execution for a fraction of a second, and then a DoubleClick can cancel the timer.
          Will only work on SU8 or later as the timer in previous versions was bugged, rounding everything down - the minimum you could defer would be a second in them versions.
          • Dan RathbunD Offline
            Dan Rathbun
            What is order of UI::Tool class callbacks called by Sketchup, when a user double clicks the Left Mouse Button, including onKeyDown() and onKeyUP() ?
            I'm not here much anymore.
              Jim
              Seems LButtonDown and LButtonUp always and only occur once each, followed by onLButtonDoubleClick if there was an one.
              Here's the double-click output from the script below:
              ` onLButtonDown
              onLButtonUp
              class TestTool
                  def onKeyUp key, repeat, flags, view
                      puts ;onKeyUp
                      add_newline(Time.now)
                  def onKeyDown key, repeat, flags, view
                      puts ;onKeyDown
                  def onLButtonDoubleClick flags, x, y, view
                      puts ;onLButtonDoubleClick
                  def onLButtonDown flags, x, y, view
                      puts ;onLButtonDown
                  def onLButtonUp flags, x, y, view
                      puts ;onLButtonUp
                  def add_newline(t)
                      UI.start_timer(1) { puts "-" * 25 }
              Sketchup.active_model.select_tool TestTool.new
                c.plassais
                Dan is to prohibit the use of onKeyDown ()and onkeyup ()when a user double clicks the Left Mouse Button.
                As Jim says, the solution is perhaps to calculate the delay between two onKeyUp (), if the delay is small consider that a double click to invoke a method equivalent onLButtonDoubleClick. if not call the method onKeyUp () and / or onKeyDown ()
                  c.plassais
                  Thanks Jim
                  What do you think about this
                  class TestTool
                          puts "-" *25
                          puts ;onLButtonDown
                          @id = UI.start_timer(1,false){call_method(flags ="single", x, y, view)}
                          puts ;onLButtonUp
                          UI.stop_timer @id
                         call_method(flags ="double", x, y, view)
                      def call_method(flags, x, y, view)
                          if flags == "single"
                              UI.stop_timer @id
                              puts "Call method for onLButtonDown"
                              puts "Call method for onLButtonUp"
                          else
                              puts "Call method for onLButtonDoubleClick"
                          puts "-" *25
                  should be able to reduce the UI.start_timerto less than 1 second....
                    c.plassais
                    It works, you can use onLButtonDoubleClick without calling onLButtonDown & onLButtonUp
                    The delay time is 0.2 it works well for me but it is possible that changes depending on the computer
                    For SU8
                    class TestTool
                        def onLButtonDown(flags, x, y, view)
                            puts "-" *25
                            puts ;onLButtonDown
                            @ip = UI.start_timer(0.2,false){call_method(flags, x, y, view)}
                        def onLButtonUp(flags, x, y, view)
                            puts ;onLButtonUp
                        def onLButtonDoubleClick(flags, x, y, view)
                            UI.stop_timer @ip
                            puts "-" *25
                            puts "-" *25
                    For SU6 & SU7
                    class TestTool
                            puts ;onLButtonDown 							# for test
                            puts ;onLButtonUp							# for test
                            UI.stop_timer @id
                            puts ;onLButtonDoubleClick						# for test
                            puts "Call method onLButtonDoubleClick"					# for test
                            puts "-" * 25 								# for test
                                start_time = Time.now
                                elapsed_time = 0
                              	loop do
                                       elapsed_time = Time.now - start_time                         # for test
                                       puts elapsed_time
                                      	if elapsed_time >= 0.20   				###### delay time ######
                                                    @id = UI.start_timer(0,false){
                            			puts "Call similar method for onLButtonDown"
                                        		puts "Call similar method for onLButtonUp"
                                        	break
                    ChrisP
                      Under Windows this can be configured by the user. Registry setting. Expect one can set it under OSX - but I have no idea where you'd get the setting.
                        c.plassais
                        In the script, it's just the time allowed to detect the double click
