    Getting bounding box in custom axis
    10 Posts 3 Posters 984 Views 3 Watching
    • PixeroP
      Pixero
      I need to find the bounding box max and min for a selection in a custom axis.
      Is there a way to find the min and max vertices position from a custom axis such as for example the view direction?
      Is there another better way?
      • Dan RathbunD
        Dan Rathbun
        see Group.local_bounds
        I'm not here much anymore.
        • PixeroP
          Pixero
          Thanks, but would it work for getting the bounds for the selection in the view direction? Something like this.
          • Dan RathbunD
            Dan Rathbun
            No.. sorry.. now (with your pic,) I see what you want.
            If you could temporarily align the axis to the view, then the bounds would return what you want. BUT.. the API does not allow access to the Axis as a Ruby object.
            • Dan RathbunD
              Dan Rathbun
              It may be possible to temporarily transform the selection to align to the view, then change the camera to align to the axis, get your bounds, then reset the view, and undo the tranformation.
              • PixeroP
                Pixero
                I'm thinking loud here:
                Would it be possible to get the bounding box for the selection the ordinary way and then compare the min and max values of the bounding box in the Camera.xaxis and Camera.yaxis to see which is highest and lowest and use those values to generate a "view bounding box"? No idea how to do it though...
                  [attachment=0:7iscdulp]<!-- ia0 -->Viewbounds.jpg<!-- ia0 -->[/attachment:7iscdulp]
                  Project the position of the vertices in the selection to the screen and use the projected points to create a new boundingbox?
                  • PixeroP
                    Pixero
                    I dreamt the solution last night and so far it's working. A few things to fix though. πŸ˜„
                    What I'm doing is to get the bounding box of the selection the regular way.
                    Then make a copy of the boundingbox points in a array and rotate them around the center to match the camera rotation. Then test those rotated points in worldspace to see which are max and min for the different x, y, z axis and then use the corresponding bbox.corner index to create a new rotated bounding box.
                    Easy peasy.... perhaps not, but it seems to work.
                    By the way, any good example how to test the points to see which is max and min?
                    • Dan RathbunD
                      Dan Rathbun
                      BoundingBox.max
                      BoundingBox.min
                      In addition, the Ruby standard Array class has the Enumerable module mixed in, which gives all Arrays a max and min method.
                      In the Sketchup API, Point3d class is compatible with Array.
                      • PixeroP
                        Pixero
                        Thanks.
