Apple compatibility
Aside from the pc only "Sketchup.send_action" commands, how do I know what plugin coding will not work on Apple?
Most will work on both platforms. But there are the occasional platform specific bug. For instance, File methods will only work with ASCII filenames under Windows, while under OSX they can be Unicode. It is usually the system commands that will not work on both platforms.
Sounds like the only way to check it, is to run the app on both platforms?
