    [Test] defn.count_instances vs defn.instances.lenght
    3 Posts 2 Posters 374 Views 2 Watching
      I was curious of why there was a method definition.count_instances - as I've often just used definition.instances.length. Did a quick test:
      d=Sketchup.active_model.definitions[0]; c=1000; puts "Counting #{d.count_instances} instances..."; t=Time.now; c.times { d.count_instances }; puts "Count: #{Time.now-t}s"; t=Time.now; c.times { d.instances.length }; puts "Count: #{Time.now-t}s";
      Counting 8642 instances... Count: 0.0s Count: 1.748s
      Significant difference.
      In order to get .count_instances to be of notisable lag I needed to go over 1,000,000 iterations ( 0.38s). With 10,000,000 it took 3.678s. I did not even try to test with definition.instances.length with that many iterations.
      • Dan RathbunD
        Dan Rathbun
        Reason: The count_instances method queries the C++ side for an integer.
        Each time you call the instances method, the C side API has to allocate a Ruby Array object which has as it's members, pointers to all the definition's C++ instances collection.
        Your test might get closer if you have a statement like i=defn.instances outside the loop. Ie, create the Array only once, then have i.length inside the loop's block.
        If you do not need a Ruby Array, then count_instances should always be faster.
        This is a candidate for the Optimization topic.
        I'm not here much anymore.
          Duh! Should off course have eliminated new object creations. (They are all too expensive.)
          Changing it and the numbers are quite different:
          d=Sketchup.active_model.definitions[0]; inst=d.instances; c=10000000; puts "Counting #{d.count_instances} instances..."; t=Time.now; c.times { d.count_instances }; puts "Count: #{Time.now-t}s"; t=Time.now; c.times { inst.length }; puts "Count: #{Time.now-t}s"
          Counting 8642 instances... Count: 3.562s Count: 1.795s
