    KML/GE question
    Scheduled Pinned Locked Moved Google Earth
    37 Posts 4 Posters 21.9k Views 4 Watching
      jaxcoffee
      @leedeetee said:
      As ever Gai, thank-you, I will have a think and investigate my options.
      Hey Lee,
      If your models are in a collection, it will create it's own KML file called Placemarks. Click on View in Google Earth off the collection and save the file to your desktop. Double clicking on that file will open it up in Google Earth.
      Once it does, you can right click on it in Google Earth and save it as a KMZ file with what ever name you want.
      Then you can import that KMZ file into My Maps, and the end result is something like this.
      http://goo.gl/uBBKc
      • leedeeteeL Offline
        leedeetee
        Good morning Jack,
        That is wonderful, thank-you. I think this could be exactly what I am after. πŸ˜„
        Edit: I have done this Jack, and it would be perfect, but when opening in google earth, it only shows two models (out of 29). 😳
          This does not seem to work for me at all. I have a collection with a single model in it and what GE displays is this:
          In GMaps, my kmz to import never loads (the browser is just loading, loading, but nothing...)
            leedeetee
            Yes, It's strange Gai, I have uploaded 29 models to a collection, yet mine only shows 2 models, both seemingly picked at random.
              Are they all publicly shared?
                leedeetee
                Yes, with identical access settings and details as the other 27. πŸ˜•
                  can you share the kml file? I wonder what should be "inside" - compared to my own.
                    leedeetee
                    Certainly ....
                    Placemarks
                      leedeetee
                      And here is the collection:
                      Error 404 (Not Found)!!1
                      (sketchup.google.com)
                      Which shows all of the models in the "preview" window.
                        Thanks. I really do not know what causes all these models to fail to get listed.
                        However they do not automatically load either. If you turn off the 3D Layer, they will not show up unless you "View in Google Earth". What I would really like to do is to load only those hat are listed (certainly the user would need to turn off the 3D Layer for this) but load automatically.
                        But your "View in GE" link there gave me finally the answer to how to load WH buildings with kml! (see the southpark kml attached - make sure your 3D Layer is off!).
                        Now also see your placemark attached where I separated the two models that only load for you with comments starting with # characters (these lines will not load in the xml file).
                        If you really want, you can add any other model manually, changing the links and whatnot in the table cells.
                        SouthFolkRehab.kml
                        placemarks-lee.kml
                          leedeetee
                          How is it best to open the .kml files as text??
                            In the context menu there is an item whose name I don't know in English. There you can open in a simple text editor.
                            Or even easier; drag and drop the kml file onto the quick launch icon of your text editor.
                              leedeetee
                              Thanks Gai, I'll have play.
                              I just wish I knew/could understand why it won't work like it should do, as Jack's obviously does.
                              Cross Alantic shout to Jack!!!
                                jaxcoffee
                                How long has it been since you created the collection, and uploaded models to it?
                                  I have that collection (old one, at least a year) where I updated the model some time in May. No model is listed at all.
                                  I also noticed something weird. When yopu show a model in GE, from some models, only a kml file is downloaded and inside the kml file there is reference to the WH model.dae (and images). For other models, the whole kmz file (including dae and images) is downloaded.
                                    leedeetee
                                    This morning .....
                                      jaxcoffee
                                      This morning .....
                                      I can't think of anything else that would cause the KML file not to produce. Giving it a day or so to migrate in would be my only suggestion.
                                        Jax, and how about my model and collection? That model is 1.5 ys old and last updated in last May.
                                        πŸ˜’
                                          jaxcoffee
                                          πŸ˜’
                                          Sorry Gaieus,
                                          I hadn't had a chance to look into what issues your were talking about. I was concentrating on Lee's issues. What is it that your experiencing?
                                            leedeetee
                                            Just a little more info. This is so strange.
                                            I was trying to understand this, so I checked all my other collections, which all appeared in 'view in google earth fine, and produced a correct placemarks.kml file.
                                            • I deleted the original collection that was causing problems, and started a new one, adding all the models again. I kept checking back reguarly, and the placemarks.kml was absolutey fine. UNTIL I added the Agar and South Fork models (these were the only 2 showing in my original problem). I now only get these two models shown in the placemarks.kml file.
                                            • I deleted the Agar and South Fork models from the collection, and launched the placemarks.kml file. Now, despite their being 28 other models in the collection I get a singular 'No data' placemark with no models shown.
                                            Do you know of how I can contact google about this? Is there a mail address or an official forum? Would really like to get to the bottom of it.
                                            • 2 / 2
