    Animation
    2 Posts 2 Posters 425 Views 2 Watching
      danielito
      I have designed a big house.
      Now I want to make an animation and show it how it looks inside the house.
      When I make an animation with schetup it creates a huge avi file of 600 mb and the animation is 40 sec. And it takes long time...But thats not the problem i have time. its the size.
      Because I want a good quality of the animation I use 1200X 700.if I reduce the frames there result is very bad.
      Now I wonder if there is another aplication where I can make animation. I want to make an animation not larger than 5 mb and good quality.
      Is there some plugin for sketchup 7 pro.
      This movie will be in the webbpage at my work, so a need it to be small file.
      Is it 3d studio max or what?
      or ADOBE PREMIERE ELEMENTS
      My email danielito12345@gmail.com
      Sweden
      Sincerely,
      Daniel
        Speaker
        Good quality comes with long render times, and there is nothing you can do about it in any program you use. I would suggest you to convert the avi file to a different format to compres it, like MPEG-4 to get the best quality with the lowest bitrate. Just google for "avi to MPEG-4 converter" and you should get loads of options. Experiment what quality you can get under those 5mb. Also I would suggest you to do some reading about this topic to better understand how all of it works to get the best results.
        http://www.youtube.com/user/latvietis1234
