    Spirixcode: revolve / extrude plugin
    3 Posts 3 Posters 1.9k Views 3 Watching
      Jim
      Just a heads-up. Appears to be under construction, although sections A and B have been filled out.
      Basically, the plugin allows you to revolve or extrude any 3D sequence of edges (both open and closed loop) about or along the z-axis while rotating, scaling, and/or morphing the selected edges using various interpolative functions. The code utilizes linear, sine, arc1, arc2, arc3, arc4, log10, parabolic, and cubic transforms independently applied to the scaling, axial, radial, and morphing operations.
      spirixcode
      The Chaos Trilogy: Better Life Through ACME Available in Kindle format and paperback from Amazon. Spirix Plugin for SketchUp (works with SketchUp 2015, 2016, and 2017) The Spirix Ruby plugin allows you to revolve or extrude any 3D sequence of edges (both open and closed loop) about or along the
      (sites.google.com)
      • Didier BurD Offline
        Didier Bur
        Looks promising, nice find !
        DB
          Seems miss a chapter (move + size + rotate in the same time) πŸ˜„
          but this one yet exist: Grow by TIG πŸ˜‰
