    FaceMe - Ruby\SU bug?
    2 Posts 2 Posters 268 Views 2 Watching
    • T
      tomasz
      When playing with images I have discovered something strange with nested FM components.
      Check the SU file attached.
      In SU6 the bug is most obvious. Just try to draw a line on vertical rectangles.
      The faces in the second component will go wild. In SU6 they will even double themselves.
      In SU7 & 8 this error is present in a shadow that flickers as in SU6, but the faces stay still in a view. Unfortunately shadow is not the only one thing affected. The transformation of the second FM component is being constantly changed. It is impossible to export the second component in the position shown in a view, because the view lies. I think shadow reflects geometry real position.
      I don't recall this being reported before.
      FM_RubyBug.zip
      Sample export - always different
      • K
        kwalkerman
        Something similar happens when you create a new group inside an existing group that consists of existing components. See this thread:
        404 Not Found
        (forums.sketchucation.com)
