    Intercept UI::Command.new ?
    7 Posts 4 Posters 378 Views 4 Watching
      Is there a way to intercept UI.Command.new so that one can catch the menu_name argument passed to the new method ?
        never mind - think I got it working now... I think...
          Eeeexcellent!
            AlexMozg
            It is possible so:
            module Object;;UI
            	class Command
            		class << self
            			alias ;newORIG ;new
            			private ;newORIG
            		def self.new(m_name, &cmd_block)
            			p m_name #some code...
            			self.__send__(;newORIG, m_name, &cmd_block)
            		end#def
            end#module
            • Chris FullmerC Offline
              Thom, this looks very intersting. Are you going to post some working code or a plugin here soon?
                Need some more coding.
                I've intercepted all the menus created and added getter methods. With this I should be able to override the menu and toolbar structures. It's all going to take a lot of UI development, but what I'm thinking is:
                Being able to:
                • Override menu & toolbar text, tooltips, statusbar text
                • Override menu location (user defined menu structure)
                • Custom toolbars of any Ruby toolbar buttons (Though there can be issues here with plugins trying to hide/show their own toolbars)
                • Mute menus and toolbar buttons
                • Automatic menu sorting or custom arrangement (need to find a good solution for this)
                Regarding automatic menu sorting or custom arrangement there are some issues:
                Idea 1 - pre-populate the menus and hook up the commands when the plugins loads. Issue here is if a plugin is removed there'll be dead menu items. (Purge menu command?)
                Idea 2 - Find a way to work out when SU has loaded all plugins upon SU startup - populate menus when they are done.
                • PixeroP Offline
                  Pixero
                  Very interesting. Awaiting your TT_toolbarTool... 😉
