Manipulate a ruby from command line?
Hey, just wondered if there was any way I could launch sketchup as follows: sketchup.exe -rubyname "string"
essentially, I want a ruby script take the string, do some automated modelling based on what's in that string, and save the file... think this is possible?
Thanks,
Tom
see Sketchup Bridge - http://labs.plugins.ro/
WOW!!!!!............
hmm, I could do with a "hired gun" to get this sorted for me. do you guys know of anywhere I might be able to find someone?
Thanks,
Tom.
Yes, it's possible. It sounds like you want to batch-process some models. SketchUp won't run in any sort of window-less mode - the gui window is always opened.
SketchUp does have a command-line switch that will execute a Ruby script:
Sketchup.exe -RubyStartup "C:\Scripts\My Script.rb"Maybe related: Dan Rathbun posted some code for closing Sketchup here:
http://forums.sketchucation.com/viewtopic.php?f=180&t=29162 -
you guys are very helpful.
Jim, do you know if you could also send through a variable with the switch, like so:
Sketchup.exe -RubyStartup "C:\Scripts\My Script.rb" -variable
No, but you could use an Environmental variable which is accessible via the script. Or simply have multiple scripts which hard-code the value in the script since you are able to select any script on the command-line.
ah yes,
I guess I could insert a line into the ruby on the fly... basically a variable with the relevent string.
Ok, getting somewhere now!
1 more thing, I assume I could automate a save operation too?
thanks,
Tom.
You can save the whole model:
http://code.google.com/apis/sketchup/docs/ourdoc/model.html#saveOr you can save individual ComponentDefinitions:
http://code.google.com/apis/sketchup/docs/ourdoc/componentdefinition.html#save_as -
Let me correct my answer to: I don't know. It may be possible to pass arguments to the ruby script, although I have not tried:
Sketchup.exe -RubyStartup "c:\Scripts\My Script.rb SomeString" -
ah, OK cheers Jim.
It looks like it will be possible one way or another!
now I know its possible, time to hunt down someone with the capabilities
Thanks a lot for the help,
Tom
