    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Manipulate a ruby from command line?
    11 Posts 4 Posters 688 Views 4 Watching
      mut
      Hey, just wondered if there was any way I could launch sketchup as follows: sketchup.exe -rubyname "string"
      essentially, I want a ruby script take the string, do some automated modelling based on what's in that string, and save the file... think this is possible?
      Thanks,
      Tom
      http://www.StairBox.com We make stairs... easy
      • tbdT Offline
        tbd
        see Sketchup Bridge - http://labs.plugins.ro/
        http://plugins.ro
        • honoluludesktopH Offline
          honoluludesktop
          WOW!!!!!............
            mut
            hmm, I could do with a "hired gun" to get this sorted for me. do you guys know of anywhere I might be able to find someone?
            Thanks,
            Tom.
              Jim
              Yes, it's possible. It sounds like you want to batch-process some models. SketchUp won't run in any sort of window-less mode - the gui window is always opened.
              SketchUp does have a command-line switch that will execute a Ruby script:
              Sketchup.exe -RubyStartup "C:\Scripts\My Script.rb"
              Maybe related: Dan Rathbun posted some code for closing Sketchup here:
              http://forums.sketchucation.com/viewtopic.php?f=180&t=29162
                mut
                you guys are very helpful.
                Jim, do you know if you could also send through a variable with the switch, like so:
                Sketchup.exe -RubyStartup "C:\Scripts\My Script.rb" -variable
                  Jim
                  No, but you could use an Environmental variable which is accessible via the script. Or simply have multiple scripts which hard-code the value in the script since you are able to select any script on the command-line.
                    mut
                    ah yes,
                    I guess I could insert a line into the ruby on the fly... basically a variable with the relevent string.
                    Ok, getting somewhere now!
                    1 more thing, I assume I could automate a save operation too?
                    thanks,
                    Tom.
                      Jim
                      You can save the whole model:
                      http://code.google.com/apis/sketchup/docs/ourdoc/model.html#save
                      Or you can save individual ComponentDefinitions:
                      http://code.google.com/apis/sketchup/docs/ourdoc/componentdefinition.html#save_as
                        Jim
                        Let me correct my answer to: I don't know. It may be possible to pass arguments to the ruby script, although I have not tried:
                        Sketchup.exe -RubyStartup "c:\Scripts\My Script.rb SomeString"
                          mut
                          ah, OK cheers Jim.
                          It looks like it will be possible one way or another!
                          now I know its possible, time to hunt down someone with the capabilities ๐Ÿ˜›
                          Thanks a lot for the help,
                          Tom
