    My render - your opinion?
    16 Posts 8 Posters 2.1k Views 8 Watching
      alexandersimple
      @jarynzlesa said:
      Re: My render - your opinion?
      try this: http://forum.asgvis.com/
      damn... why are some people so vicious?
      this render is sure better than i can do just playing around with vray
      • KrisidiousK Offline
        Krisidious
        if you had to live in the Czech Republic you'd be angry too...
        By: Kristoff Rand
        • coulteriC Offline
          coulteri
          What´s wrong about Czech republic? 😄 I´m glad to live here 😄
            Krisidious
            Coulteri,
            I'm just teasing... we love all of you former eastern block countries... vive la resistance!
            I was alluding that maybe years of Soviet Domination made Jarynzlesa so mean.
            By: Kristoff Rand
            • coulteriC Offline
              coulteri
              I understand and I´m surprised, that you know, where our country is. In Czech language "Jarynzlesa" means something like "Jaroslav from the forest" ......
                Roger
                Some rough ideas
                This is just to give you some ideas. It is all done in post production and is a bit sloppy as I was in a hurry. Photography, even virtual photography is more about composition and lighting than the subject itself.
                http://www.azcreative.com
                  liam887
                  @krisidious said:
                  Coulteri,
                  haha
                  anyway Roger is indeed right im not too familiar with Vray but I would work on your composition and also the model itself. Maybe a few more details would not go amiss just take you time add some guttering, a handle on the garage etc.
                  As for the materials im sure there are libraries you can download online for vray for SU? Good luck anyway for a first go its not so bad I have seen much worse dont worry!
                  VISIT MY ONLINE GALLERY
                    Scostumatu
                    @roger said:
                    [attachment=0:2wruatvw]<!-- ia0 -->toot.jpg<!-- ia0 -->[/attachment:2wruatvw]
                    WOW Roger that looks 100% better!!! I need to develop my photoshop skills... any idea where i can learn to do something like that?? Im not too bad at photoshop but I havent yet learnt to do something like that!
                    thanks very much!
                      Roger
                      Yes, I did this with photoshop, but it would be better to do most of it in the original model as that is more precise.
                      Having said that I often finish a model and render and still see things I think I could improve in PS. That goes for my photography to.
                      Lets have a go at walking you through the process.
                      First take the lasso tool an change it to the angular lasso rather than the soft lasso. Now out line all your windows so they are surrounded by the marching ants. Then with the windows selected, go to "levels" and move the two sliders so they are at the toe of the slope on the left and right of the curve. You can also adjust the middle slider a bit if that helps the look. Click OK. Withe the selection still made, go to "change color balance" and on the high and mid range, move the yellow slider to the left and the red slider to the right.
                      Post the modified render so I an see it and we will go from there.
                        Roger
                        Actually, there is something we should have done first which is to outline the house and do the routine with changing the levels on the whole house before even touching the windows. We need some light on the building to even make it seeable before even starting on the details.
                          Scostumatu
                          Thansk Roger much appreciated!
                          I reworked the render a little and amended it somewhat adding more lighting. TOnight when I get home I will do as you said and use photoshop to edit the lighting. That sounds interesting!
                          In teh meantime, pls see the updated render (no photoshop)
                            Scostumatu
                            Hi Roger - here it is.... adjusted the levels along with the colour balance (midtones)
                            Thanks again
                              Sully114
                              Hi your main problems are coming from tone mapping and exposure, if you adjust your image so its correctly exposed before you start adjusting material properties you will get a much better render. Im a bit out of practice with Vray but in Vray for 3dsmax you can adjust your exposure in the camera settings using tradition camera settings like F-stop and shutter etc.
