    [code] Win32 Moving/Showing/Hiding Toolbars and Dialogs
    91 Posts 8 Posters 23.7k Views 8 Watching
      It can - I used to do it in Visual Basic when VB didn't offer full control over the windows. You can in fact change any window of any app - as long as you get its handle.
        Jim
        Yep, just did it. I'm just wondering of I am not writing a library that has already been written...
          How quickly can you get the window handle when opening webdialogs? Can you avoid a flicker of change?
            Jim
            Good question I don't know the answer to, but wouldn't the reliable way be to have the dialog send a message back to ruby when it's ready?
            Or can you change the dialog to a toolwindow before you .show() it? Will need to test.
              Maybe the .show event of the dialog triggers as it's displayed? But I'm not sure if it wait for the HTML - which you do not want - as that will lag.
              And can you do anything before calling show? You need a handle to the window - how are you getting that at the moment?
                Jim
                What does it mean when I get a negative value for a window style? How do I decode it into it's positive representation?
                  From GetWindowLong?
                    Jim
                    yeah.
                    s = get_style("Ruby Console") -1798569916
                      hm....
                      Are you receiving the data in the correct data type?
                        Jim
                        Turns out the negative return value is not a problem - I just wasn't using it right.
                          Jim
                          Using FindWindow - which is a basic search by window name and class.
                            Jim
                            For a WebDialog, I couldn't find a handle until it was shown. I used EnumWindows and EnumChildWidows to locate it.
                            But I didn't see a lag when applying the ToolWIndow class immediately after .showing the webdialog.
                              Neat! 😄
                                Jim
                                The Win32API.so file does not support the use of callbacks needed by EnumWindows and EnumChildWindows. So I have had to move to win32/api.so, which does support callbacks. But this will also allow more interesting things to be done, such as finding resizing Sketchup by its drawing area, and sending values to the Measurements box via a plugin.
                                  When there is multiple SketchUp windows open - how do you find the one you want?
                                    Jim
                                    Hopefully, the window titles are different. If not, I'm not sure.
                                      So you look for windows with "<filename> - SketchUp (Pro)"
                                        Jim
                                        Too fast... here's how to get the exact name. (But is_pro? is for windows 7+)
                                        def su_window_name
                                            pro = Sketchup.is_pro? ? " Pro" ; ""
                                            if ((title = Sketchup.active_model.title).empty?)
                                                return ("Untitled - SketchUp" + pro)
                                            else
                                                return (title += ".skp - SketchUp" + pro)
                                          But when there is two untitled windows there could be problems?
                                            Jim
                                            Yes, but in that case how would any program know which one the user meant?
                                            You can find all of the matching windows. It's just hard to know which the user meant to use.
                                            • 1 / 5
