    Interacting with a Sketchup file from another program
    21 Posts 7 Posters 6.9k Views 7 Watching
    • Chris FullmerC Offline
      I do not think there is a way to work with SketchUp the way you are describing. There is the SDK that allows you to work with the model, but not SketchUp.
      A possibility that does come to mind though is that I think you might be able to export images of the model through the SDK. So maybe you could allow the user to enter their data. THen your app could alter the model according to the user's data. And it could export images for each frame. You would probably have to manually alter the model for each frame. Then export each image, and write your own viewer to turn those images into an animation.
      I'm not sure its possible, but it sounds plausible to me, though its a bit of a workaround I think.
      • daleD Offline
        dale
        Now back to Sunpaths. The SunTools plugin has caused some conflicts with other programs I believe Thea is one. I have used it before with good results but never on a webpage. There was a website that had this very thing, I'll see if I can find it as I posted it's location on another forum once.
        PS (Sorry about the beer "Stein" hijack)
        • numbthumbN Offline
          numbthumb
          Hey dale, it says Error 404 - File Not Found. Where do I find that?
          Oh, and cheers, Simon! 😉
          Comfortably numb...
          • daleD Offline
            dale
            Here is a link to the site mentioned above.
            http://astro.unl.edu/naap/motion3/animations/sunmotions.html
            I don't know if it will be of any use for what you are asking, but it's a cool little tool, so I thought I would post it.
            Cheers
            • daleD Offline
              dale
              I think I fixed the link, it works on mine now. Sorry.
              Nice avatar!!!!!
                numbthumb
                Thanks! Yes, it works here, too.
                Comfortably numb...
                • simon le bonS Offline
                  simon le bon
                  Hi Dale,
                  Your "Motions of the Sun Simulator" is bookmarked _ 👍 😉
                  Hi numbthumb,
                  I can't believe you have taken it 🤣
                  the picture is taken from a very smart set: Oktoberfest 2010 😉
                  and I have recover the set mine come from: Singapore 2010 Youth Olympics
                  @thread users: sorry for my little bumping 😄
                  simon
                    I think the original poster got scared off. Hopefully he'll come back. This was an interesting topic.
                      simon le bon
                      Come on Chris, it is not a big disturbing, just a little be-bop-bump of happiness.
                      It seems that Pigbite had registered mainly to find an answer to this specific question. As I was thinking he was going to miss the answers, I had send him a PM to tell him about my answer (1001shadows). And the message had been read. So he has surely read also your reflexion around the subject (using SDK (software development kit)...which is too much for me 😕 )
                      I now shut my mouth. ++simon.
                        Oh I'm not really that worried about the off topic. He'll come back if he wants I suppose.
                          Pout
                          I think you could so something like this with Hypercosm.
                          We are working on letting a Sketchup model (well an export of that model) evolve in time on a webpage
                          some pics of the alpha stage:
                          • Dan RathbunD Offline
                            Dan Rathbun
                            I think the answer is to export as Collada (.DAE,) and have the website use the Google O3D plugin. (Manipulation and User Interaction is done via Javascripting.)
                            I'm not here much anymore.
