    Using printf to help trace ruby errors
    2 Posts 1 Posters 495 Views 1 Watching
    • Al HartA
      Al Hart
      After creating a script to trace ruby output to a file, I thought it might be a good idea to add a trace to every function call, with a line like this:
      printf("FILE; %s; Line; %s\n", __FILE__, __LINE__) if $rps_show_traces
      As in:
      def test2(ii)
      	i1 = 1
      	i2 = i1+1
      	return i2
      end#def
      if $rps_show_traces is true, I will get a trace message for every function like this:
      (Does ruby already have anything like this to help trace function calls?)
      FILE: /aa/test (2).rb: Line: 24
      However if $rps_show_traces is not defined, or false, nothing will happen.
      I wondered how much this would slow things down.
      I also wondered it a if/end#if form would be significantly faster.
      if $rps_show_traces ; printf("FILE; %s; Line; %s\n", __FILE__, __LINE__); end#if
      So I created a test ruby to execute a function with the second form (if /end#if), the first form (if) and no trace statement at all.
      Sure enough the if/end#if was faster, but after 5,000,000 function calls the time difference, and the time to include a line like this in the source at all, is insignificant.
      if/end#if: elapsed 4.787 seconds
      if only: elapsed 4.678 seconds (.10 seconds faster for 5,000,000 calls)
      no trace: elapsed 4.279 seconds (.40 seconds faster for 5,000,000 calls)
      So, although it would mess up the source code a bit, it would take no significant overhead to include a trace line after each function definition.
      Here is the test routine if anyone wants to try it out.
      def test1(ii)
      	i1 = 1
      	i2 = i1+1
      	return i2
      end#def
      def test2(ii)
      	i1 = 1
      	i2 = i1+1
      	return i2
      end#def
      def test3(ii)
      	i1 = 1
      	i2 = i1+1
      	return i2
      end#def
      def do_all
      	do_test1
      	do_test2
      	do_test3
      end#def
      def do_test1
      	start = Time.now
      	ii = 0
      	0.upto(5000000) { |ii| test1(ii) }
      	etime = Time.now
      	printf("if/end#if; elapsed %s seconds\n", etime - start)
      	ii
      end#def
      def do_test2
      	start = Time.now
      	ii = 0
      	0.upto(5000000) { |ii| test2(ii) }
      	etime = Time.now
      	printf("if only; elapsed %s seconds\n", etime - start)
      	ii
      end#def
      def do_test3
      	start = Time.now
      	ii = 0
      	0.upto(5000000) { |ii| test3(ii) }
      	etime = Time.now
      	printf("no trace; elapsed %s seconds\n", etime - start)
      	ii
      end#def
      Al Hart
      IRender nXt from Render Plus
      • Al HartA
        Al Hart
        I was trying to get the function name in the trace as well.
        It turns out that adding this line after every function definition may work well. It displays the rotuine name as well as the file and line number.
        puts("TRACE: " + caller(1)[0].to_s) if $rps_show_traces
        Al Hart
        With your input, this post could be even better šŸ’—
