    State of Observers Redux — 18 August 2011
    30 Posts 4 Posters 6.5k Views 4 Watching
      Jim
      Great work, and great resource. Thanks for doing it.
        Thanks Dan, knew it was hiding somewhere.
        Thanks for the spelling control - I didn't run a spell-checker or proofread yet.
        @dan rathbun said:
        "Depreciated" has no "i" in it. And the methods that were removed can not be "Deprecated", they are "Abandoned", "Deceased".. whatever they are no longer even in the Observer protoclass.
        It's what the API docs said. I've not tested if the events are actually removed, or just aliased to their new names...
          http://dictionary.reference.com/browse/Depreciated?r=75&src=ref&ch=dic ❓
            Oh, "Depreciated" refer to value...
            grumble something about English and too similar words
              Another issue, I imagine I read some reports on MaterialObserver.onMaterialSetCurrent not working as it should on OSX in some versions of SU?
              • Dan RathbunD Offline
                Dan Rathbun
                I did test the MaterialObserver's Bulk change method. It has been removed from the superclass, so when you create an instance of a MaterialObserver subclass, it just is not there, and if you were to explicitly call the callback, a NoMethodError exception will be raised. Ie, there is no aliasing to the individual change callback(s).
                So if you wanted to handle events in a bulk manner, you'd need to do it on the Ruby side, perhaps with a Ruby standard Observer class, or a bulkchange boolean flag variable and an Array of changed objects (each individual SU change callback would need to push it's object into the Array.)
                I'm not here much anymore.
                  Dan Rathbun
                  YES.. I posted the answer that Scott gave me. He says it's logged as an internal bug.
                  See GG post: Materials.current on OS X
                    http://code.google.com/apis/sketchup/docs/ourdoc/pages.html#add_frame_change_observer
                    Sketchup::Pages.add_frame_change_observer(FrameChangeObserver.new)
                    This, surprisingly worked.
                    I'd thought you'd have to reference the model first...
                    Sketchup.active_model.pages.add_frame_change_observer(FrameChangeObserver.new)
                      So it's bugged on SU6, SU7.0, SU 7.1?
                        bulk change event? Is that one that has been removed from the API?
                        That was a troublesome points when I made this chart - they recently removed some events from the API....
                          Dan Rathbun
                          Careful.. the collection getter method Materials.current IS bugged, the question remains, is the MaterialsObserver bugged as well. You'd need to test versions on the Mac to find out.
                            Dan Rathbun
                            Yes.. the MaterialsObserver.onMaterialRemoveAll callback was removed, as it never worked, and/or never got called. So there was no point in deprecating it.
                              I'd like to add it for historic purpose - anyone remembers it parameters?
                                Ah - already got it. 😄
                                Thought there was an event named onBulkChange, like the SelectionObserver has.
                                  aiaiai... sigh
                                    Update to include SU 8.0 M1
                                    http://www.thomthom.net/software/sketchup/observers/
                                      Dan Rathbun
                                      You have that the AppObserver::onQuit is working...
                                      It's is bugged in v8 (at least. And I did report a bug last beta cycle.)
                                      It does not wait until the callbacks return, before shutting down the application.
                                      Trying to use the callback to save plugin settings, and so forth, often fails for me.
                                      Also, trying to dettach the observer itself from within onQuit causes a GPF (if I remember right.)
                                      In addition coders should NOT open any "owned" windows (like WebDialogs and messageboxes,) during the callback, until they fix the 'non-blocking' issue.
                                      Can't remember if v7 had any of these problems.
                                        Ok - I'll add that. Never used it. All the observers I've not tried and not heard any reports on I assume is working.
                                        @dan rathbun said:
                                        InstanceObserver
                                        @dan rathbun said:
                                        what about Groups?
                                        Groups and Images all are listed in model.definition.
                                        @dan rathbun said:
                                        (Note how I changed the example, from UI.messagebox to puts.
                                        I wish the docs would do that. Messageboxes are double plus ungood - especially in observer events.
                                          Dan, how do you test AppObserver::onQuit ?
                                          If I had a test case that illustrates the symptoms I could quickly run it on SU 6-8.
                                            Dan Rathbun
                                            Tough one... as it DOES fire. (It just doesn't wait for the callback to finish.)
                                            Well I first found it because I wanted to save the pos & size of several windows using Win32API calls.
                                            But it wasn't working.
                                            So I tried putting a debug popup messagebox inside onQuit(), thinking the shutdown process should stop, until I clicked "OK". But it DIDN'T stop, the messagebox came up, but everything else shutdown. And when I closed the messagebox, it's owner (the Sketchup App window,) no longer existed, so Windows poped up the VS Just in Time debugger query box (you know.. "DO want Debug now?")
                                            So next I tried, to open a WebDialog.. and that made things even worse. (I got a post-shutdown BugSplat!) They were either GPF or "Unhandled Win32 Exception".)
                                            I was trying to call a method that saved a whole bunch of data into the Registry, and that method may have called another method as well. Anyway, I even tried "lean" the process way down, putting all statements inside the onQuit(), and removing every extra reference assignment I could. But Sketchup just would not wait. It seemed to be processing all the onQuit callbacks, in the Ruby thread, but at the same time, cleaning up the main App thread, and disposing of all it's child windows.
                                            Perhaps it's a unique thing because I want to save window object data, ...that most other plugins would not encounter.
                                            I plan to try using Ruby define_finalizer, and see if that works for me.
                                            As far as testing.. I'll have to think more on this... perhaps a trace function.
