    NPR - Digital Painting
    5 Posts 4 Posters 789 Views 4 Watching
      Ross Macintosh
      Earlier I posted an image rendered with the Render[It] plugin. I've since modified the original image using multiple FotoSketcher processed images, overlayed with the original, to build up a painted effect. I spent about 45 minutes on the rendering.
      Regards, Ross
      Morning at the beach house
      • dermotcollD
        dermotcoll
        I would be very proud of that Ross - something very relaxing about it! Nice image!
        When you burn your arse - you gotta sit on the blisters!!
        • michaliszissiouM
          michaliszissiou
          A very nice image indeed! Some more crispness maybe is needed. πŸ‘
          • utilerU
            utiler
            Very nice Ross, as is the wooden clock thread....
            I haven't played with fotosketcher yet; can you mask out edges as say the output of the Dennis Technique displays?
            Just Curious...
              Ross Macintosh
              Andrew - Fotosketcher applies adjustable filter-type effects to whatever image you bring in. It processes the image and allows you to save it. It is a simple application. Where it excels is the effects can be more realistic than the typical photoshop plugin intended to produce similar results.
              What you get out of fotosketcher relates to what you put in. It won't for instance remove the lines from your typical sketchup output. It can definitely be used as part of a 'Dennis' type method where individual images are overlaid. I attach a simple example featuring a holding cell. A sketchup 'colours-only' export was processed in fotosketcher. A 'line-only' export was processed with a photoshop filter (EyeCandy 'Jiggles') and they were overlaid with transparency.
              Regards, Ross
              Hope you never spend time here!
