WebDialog - execute_script outside of add_action_callback?
Is using execute_script outside of an add_action_callback block allowed?
My code isn't working unless I do this, but if that's the case, then how do I send information to JavaScript without JavaScript asking for it?
i.e.
This doesn't work:webDiag = UI;;WebDialog.new(...) webDiag.set_html(...) webDiag.show() webDiag.execute_script("document.getElementById('myID').value = 'abc'")
But this does:
webDiag = UI;;WebDialog.new(...) webDiag.set_html(...) webDiag.add_action_callback('update') { |web_dialog, params| web_dialog.execute_script("document.getElementById('myID').value = 'abc'") } webDiag.show() # Then JavaScript sends "update" back to Ruby...
Yea, should be. Is that your actual test code that doesn't function? Or is it a representation of another script?
Are you calling
immediately afterwebDiag.show()
In which case that is your problem, the webdialog has not manage to initiate yet.
What I do is create a load callback, then in the javascript hook into the event that triggers when the DOM has loaded and send a message back to Ruby for the load callback. Then I do the Ruby initiation stuff from there. -
What I do is create a load callback, then in the javascript hook into the event that triggers when the DOM has loaded and send a message back to Ruby for the load callback. Then I do the Ruby initiation stuff from there.Cool thanks, I'll try that.
Follow-up question: Does WebDialog DOM stay loaded when you use WebDialog.close() and then WebDialog.show()? Or do I need to wait again?
Good question. I don't know.
However, this can differ from Windows and OSX. As it does with the loading of the HTML.
From this thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=23445@unknownuser said:
On Windows, the HTML document appear to be created when you call
dialog.show
. If you attach an event towindow.onload
which send a command back to ruby to print"Hello World"
in the console you'll see"Hello World"
printed as you call.show
. But on OSX it seems that the HTML document is created as you use.set_file
or.set_html
- before calling.show
Thanks a ton, thomthom - that thread just cured about 16 of my headaches (99 more to go!). The API documentation on WebDialogs is way too minimal...
Another tip which I might not have mentioned in that article, I find using a javascript framework (like jQuery) takes the pain out of the cross-compatibility JS issues.
