    SketchUp::Image transforms
    8 Posts 2 Posters 468 Views 2 Watching
    • AdamBA Offline
      AdamB
      Anyone had any success extracting the local transform for a SketchUp::Image?
        http://forums.sketchucation.com/viewtopic.php?f=180&t=21869
        • AdamBA Offline
          AdamB
          Whoa. Great catch Alex - its the Vector3d#axes method I was missing.
          Be great to have the code behind the method (pretty please?) - the problem is that while you can generate orthogonal vectors from a normal easily enough, there is some ambiguity regarding orientation; this method obviously captures how Google chose to resolve it - but be good to know what rule they chose.
          LightUp too can now handle Images - they're great for adding surface details to models. Water stains, scratches, rubbish etc.
          [And thankyou Thomthom for the link.]
          Adam
            I wonder why Image elements don't have a regular transformation property but instead expose a separate set of methods.
            • AdamBA Offline
              AdamB
              BTW Using decals in SketchUp is pretty cool:
              http://i614.photobucket.com/albums/tt229/ElektraGlide/SUImage-test_lightup.jpg
                How do you deal with images glued to faces like that?
                Is the actual Image transformation slightly offset the faces, or is that something SU only does internally to avoid Z-Fighting?
                How are you avoiding Z-Fighting?
                • AdamBA Offline
                  AdamB
                  LightUp processes the SketchUp::Image objects and marks their material with some internal flags which changes how they're handled to ensure you don't get z-fighting. Basically uses the machinery in LightUp that is there anyway to handle transparency etc.
                    I do like that approach though. Using Images for advanced material compositing.
