    Scifi Sketchup Modeling
    454 Posts 57 Posters 96.6k Views 57 Watching
      liam887
      Your fishing in the right pond but no.
      VISIT MY ONLINE GALLERY
        GoldenFrog
        U.S.S. Enterprise?
        http://www.google.com/imgres?imgurl=http://startrekcostumes.net/wp-content/uploads/2009/07/uss_enterprise.jpg&imgrefurl=http://startrekcostumes.net/blog/14/the-ships-of-star-trek-a-closer-look/&usg=__8PLIxjkm3vwP-yKgcFERFgXQXI0=&h=288&w=450&sz=30&hl=en&start=0&sig2=f0VnYnHWZnoVyokrsMmjSg&zoom=1&tbnid=Nm1Mb-t1JXK1BM;&tbnh=138&tbnw=192&ei=VxBwTJuvIcGengeNl5TTBw&prev=/images%3Fq%3Duss%2Benterprise%26hl%3Den%26safe%3Dactive%26biw%3D1024%26bih%3D537%26gbv%3D2%26tbs%3Disch;1&itbs=1&iact=hc&vpx=702&vpy=268&dur=64&hovh=180&hovw=281&tx=171&ty=147&oei=VxBwTJuvIcGengeNl5TTBw&esq=1&page=1&ndsp=9&ved=1t;429,r;8,s;0
        Remember, great minds think alike, and fools never differ.
          GoldenFrog
          U.S.S. Reliant?
            liam887
            No I am remaking my USS Kelvin since I lost the old file in the great HD crash of yesteryear 😞
            The last one was merely a guide for painting however this one is going to go to the extreme! Combined with Octane Renderer I am expecting major results with this one!
              GoldenFrog
              Ah-right mate! Waiting with bated breath! πŸŽ‰
                GoldenFrog
                Absolutly love the separate panels too. How may segments in the path you used to followme the profile along?
                  liam887
                  It wasn't one continuos curve but several each with different segmentation to keep the detail and poly count consistent.
                  After the hull was fleshed out I cut it into 16 equal parts like a 3D pizza. Saved the rotational centre-point and then deleted the other 15 segments. I then worked on the 1/16 segment, carved in the panel lines with intersection tool, duplicated and inverted it, joined together to make a larger piece (1/8). Then i duplicated it 7 times to make the saucer section.
                  Last time I didn't do it this way, like you said I just drew a cross section and then used the follow me tool in a circle however I want this to be very smooth for some sick renders in Octane so I had to come up with this method, which I have used many times before but only when making car tires lol but its the same principal!
                    GoldenFrog
                    Ah, brilliance! Any progress?
                      liam887
                      Changed my mind, thought it would be better suited as a shield for my solar explorer model. Im going to re-design and finish that instead will be much more complicated with all the truss sections and hopefully make for a better render!
                      Second pic is with the solar arrays in the closed/protected position behind the shield and the third with them extended.
                      NOTE:
                      The ring sections are just placeholders, the more I progress I replace them with functioning modules as you can see from the difference in the 1st & 3rd pic.
                        liam887
                        bit more work playing wirh the folding solar panels
                          GoldenFrog
                          Lovely! Dazzling detail too.
                            liam887
                            Thanks. Got rid of the solar arrays on the shield for now didn't like them they need a good re design. Anyway as I have been working on layers not all of them have been visible in previous renders here is everything together. The little space shuttle is just for scale its about 35% larger than the current NASA shuttle just to give a sense of scale.
                            Just waiting till I can do it in Octane and then you will be able to see just how detailed this one is, for the moment just standard podium renders at 3076*2304px
                              GoldenFrog
                              Again, great detail, but I miss those poor, deleted solar panels...
                                liam887
                                Yeah they are back now dont worry just needed to think them over. Basically the ballistic shield protects the rest of the ship from micro meteors, dust and directional solar radiation but I had to come up with a way for them to fold behind the shield when needed. Obv this would not happen often but certain portions of the solar system especially the main asteroid belt are notorious for large enough particles to cause major damage to the arrays.
                                I think I have come up with a good design about now, so far the tech in this ship including the propulsion is all sound the closed cycle gas core nuclear fission engines and fuel system are a proposed and scientifically accepted method of propulsion as well as the rotating habitat modules and most of the other tech. The engine nozzeles need a re-design as they are placeholders from the Saturn V launch vehicles do far. Hopefully by the end of the week ill have the model finished, the poly count is extreme I wish I had a render engine that could capture the detail. he ballistic shield alone is over 80,000 faces in SU when exporting and the geometry triangulates it jumps to over 160,000
                                  sojourner
                                  Very cool, one caveat though, Your rotation sections are too small. With the size of the rotation diameter you have there you will either A) rotate so slowly as to have no useful benefits or B) rotate so fastly that Coriolis effects will make your crew sick.
                                  • boofredlayB Offline
                                    boofredlay
                                    Very nice detailed work Liam.
                                      liam887
                                      Thanks Boo i see we are neck and neck in the speed modeling lol I voted for you originally but after a few days I decided to vote for myself lol. See you at basecamp in a few days!
                                      no only the lowest floor ( from the crews perspective) gives 1G not the whole module. I havent put any scale comparison in yet except the space shuttle re-design but the ship as a whole is massive!
                                      I used the formulae:
                                      Ca = 0.011 * Cr2 * Cl
                                      Cl = Ca / (0.011 * Cr2)
                                      Cr = sqrt( Ca / (0.011 * Cl))
                                      Ca = centrifugal artificial gravity acceleration at point X (m/s2)
                                      Cl = distance from point X to the center of rotation (m)
                                      Cr = rotation rate at point X (rotations per minute)
                                      Remember that 1.0 g is 9.81 m/s2
                                      So the radius of my gravitation modules is around 300M (for now I will probably scale this up) so for to get a comfortable 1G it only needs to spin at 1.726 rotations a minute.
                                      So for the lowest floor for the crew they will have respectable 1G and the floors above the gravity will slowly decrease until they have a 0.2G.Bear in mind the modules will have a considerable spin element but still manageable and comfortable by the technology available and the stress on the crew. I designed these floors for scientific work in lower G as well as some mission defined space such as extensive hydroponics bays for study of plant and animal growth in lower gravity as well as testing on the human body in pro-longed minor gravity environments.
                                      blah blah etc but i want this ship to be accurate as long as hard theory goes.
                                        boofredlay
                                        Oh, the shame... πŸ˜„
                                        My vote is still in for yours.
                                          liam887
                                          hahah dont make me feel bad I have to vote for you now! my folks have been away all week in Poland been hosting social drinking in my house shown a few of my mates they all voted for yours haha 😞 is amazing concept!!!! If I win the next challenge will be an alien death robot or something along those lines haha! bah my uni work still has me up for the 5th day in a row in 8am although gets me in perfect synch for boulder drinking time lol!
                                            GoldenFrog
                                            Hi Liam!
                                            Great work! I am amazed at the amount of thought you put into this, like calculating the artificial gravity, and configuring the space station for various parts of the solar system.
                                            Do you read a lot of science fiction? Your technical calculations and attention to detail sound just like something out of Poul Anderson's work!
                                            --PinkSkink (GF's sister)
                                            • 22
                                            • 23
                                            • 6 / 23
