    Swivel Viewer in Picasa
    6 Posts 4 Posters 870 Views 4 Watching
      Jim
      Just a couple notes about the swivel viewer (which started life as the Web Exporter, I believe) and is now used on the 3DWarehouse. It's been open-sourced and the source code is available here.
      Also, it has been integrated into Picasa Web Albums, so if you are viewing a Web Album full-screen, you can click and drag left-right to flip through the images.
      This is actually good timing and works very well with sahi's Create images plugin: http://forums.sketchucation.com/viewtopic.php?t=30131
      Here is an album I created using sahi's plugin. View the album as a Slideshow, and click and drag left/right for the effect. The effect works on embeded albums also.
      So Picasa can be a really quick way to put a 3d view of a model online.
        Hi Jim,
        Where is that album?
          Jim
          Fixed the link.
            d12dozr
            Good to know, thanks Jim ๐Ÿ‘
            http://goo.gl/f7ooYh
              @jim said:
              Fixed the link.
              And here is one straight to the slideshow.
              Cool Jim, I did not know it can be turned this way!
              • Mike LuceyM Offline
                Mike Lucey
                Good find Jim ๐Ÿ‘
