    JS loading problem under Mac OS X SU
    14 Posts 3 Posters 2.2k Views 3 Watching
      See if you can catch any errors in the error console
      Might have to enable the Developer Tools: http://developer.apple.com/safari/library/documentation/appleapplications/conceptual/safari_developer_guide/2safaridevelopertools/safaridevelopertools.html
      • RichMorinR
        RichMorin
        I already had the Developer Tools enabled. Clicking on "Enable Extensions" allows my JavaScript to run under Safari, but of course this doesn't help the WebDialog under SketchUp.
        So, I suppose I can either:
        • try to figure out what requires the extensions
        • wait for Google to add the extensions to SketchUp
        It looks like it doesn't like the :not() syntax. The following version works under Safari, but still fails (ie, no JS activity) under SU:
        $(document).ready(
          function() {
        //  alert(1);
            var fc  = $('div.show_hide > ;first-child'      );
            var oc  = fc.nextAll();
            var sw  = ' (<a href="#">show</a>)';
            fc.append(sw);
            oc.hide();
            $('a', fc).click(
              function(event) {
                var div  = $(this).parent().parent();
        		    var fc   = $('> ;first-child',       div);
        		    var fca  = $('a',                    fc);
                if (fca.text() == 'show') {
                  fca.text('hide'); oc.show();
                else {
                  fca.text('show'); oc.hide();
        In fact, even this doesn't work under SU:
        $(document).ready(
          function() {
            $('h3').addClass('blue');
        Tracking this down with a number of cases, it appears that $(document).ready() never fires, whether in the HTML file or the invoked JS file.
        • Dan RathbunD
          Dan Rathbun
          %(#804000)[<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">]
          Do you need XHTML Strict ???
          .. or can you try HTML 4.01 Strict .. or Transitional ??
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            I am SO surprised that Google Corporate has not yet made Sketchup "support" Google Chrome as THE WebDialog engine for Sketchup.
            • Dan RathbunD
              Dan Rathbun
              You could try your own ready trap:
              see this post: Re: PC v MAC webdialog populate
              • RichMorinR
                RichMorin
                I'm only using Strict because ThomThom recommends it. That said, changing DOCTYPE to Transitional does not make any difference.
                Following the advice of a JS hacker, I changed the way I was telling the code to run in my JS file. Specifically, I added onload="main()" to the body tag and used main() as the name of the function in my foo.js file.
                I then performed a minimal test, without jQuery, to see if I could get that working. After adding id="foo" to my (only) h1 header, I tried:
                function main() {
                  var foo = document.getElementById('foo');
                  foo.innerHTML = 'Hello, World!';
                This worked under SketchUp, proving that it could use JS from a file. I then added a number of lines of code (that worked in Firefox and Safari), to see what transpired:
                function main() {
                  alert('main 1');
                  $('h3').addClass('blue');        //T - Ignored
                  var fc  = $('div.show_hide > ;first-child');
                  fc.append(sw);                   //T - Ignored
                  oc.hide();                       //T - Ignored
                As the comments indicate, at least some of my jQuery methods are being ignored by the WebDialog. I'm not sure how to proceed at the moment. One possibility is that the version of jQuery I'm using (1.4.2) is incompatible with SU 7.1. If anyone can speak to this question, please do!
                  XHTML4 vs HTML4 doesn't really make a difference. Not unless you send the XHTML as XML.
                  Strict vs Transitional will make a difference - though personally I prefer strict as I find the rendering more predictable as transitional appear to have more cross platform quirks.
                    That is odd... using jQuery's load event didn't work - but the old onload did?
                    I've not had any problems with the jQuery's event.
                    I use that version of jQuery. I also used 1.3.x - had no problems in SU6-7.1 on either Windows or OSX.
                    This is puzzling...
                    I've not been fully able to wrap my head around what your code does - or intend to do.
                    • Dan RathbunD
                      Dan Rathbun
                      It's not a baseref issue? All the script files ARE getting loaded while running inside SU ?
                      • RichMorinR
                        RichMorin
                        It turns out that the relative paths to my library JS (and probably CSS) were working under the browsers, but not under SU. !@#$%^ (Thanks, Dan!)
                        • Dan RathbunD
                          Dan Rathbun
                          Ok that's a common booboo, nothing too bad.
                          There's a fix we talked about in another thread where we were brainstorming how to set up a "mini" 3Dwarehouse for Eric's SketchTHIS.net website:
                          Re: Download to Sketchup button
