Hobbnob's WIP Thread
this is my workflow for presenting my models when not rendering, although ive used PS you can use free versions such as GIMP etc
wow, they are good, if i can ill show you the ship im doing at the moment. its much better than just the plain old sketchup picture.
looks good but the front of the hull needs much more detail, and the wash needs work
New project today, chieftain wasnt' really going so well so i started work on a scimitar, and as I had the whole day free. . .
Awesome! The British flag adds that perfect touch
How 'bout making the main gun larger.
yeah i said that to him aswell.
looks amazing and beats mine.
few problems: SMOKE GRANADE LAUNCHERS!!!!!!!!
Well hearing both camokid's and golden's criticism I made the gun bigger and added smoke launchers, as well as a few other things.
The most notable addition is that of bar armour, used in Afghanistan to counter RPG threats.These renders were done in kerkythea, criticism is welcome
Looking good!
looking good, you should stick to one model for a while and really go to town on it. If you look at some reference images on google you can see al the details you could add to this model.
Put some panel lines in for a start. Also the headlights are restricted by the cage you should raise them and put them either side. You can use this for reference it shows good details for the front and side http://upload.wikimedia.org/wikipedia/commons/b/be/MCV-80.jpg
Liam, the real thing doesn't have panel lines, and it doesn't have raised lights either. The link you gave is to a warrior IFV, a different vehicle.
This is the one i'm making
ahh my mistake I thought you where trying to build a warrior.
Finished the first version of the scimitar, this one is in greens without bar armour:
I would suggest working on it a lot more, there are lots of features that could be improved and details that could be added, I would not leave it as it is now.
Fair enough, what have I missed out? I know theres a lack of detail on the front area and on the storage boxes, and the turret is mostly improv, but i'm not seeing anything major missing?
Well if you look at a photograph of you model there are many details that could be added. I would separate the model into 9 or 10 different groups then spend a day or so working on each. Instead of making so many models of the same standard I think it would benefit you to concentrate on just one. Focusing on one project helps you to improve your skills and also the better the end result and final model!
You have lots of flat geometry that you could attach 'functional' greebles too so to speak. Good luck! -
Liam887, thanks for the feedback, is this any better?
lol, i never noticed the rocket launcher on the front.
looks very good, well done
Cheers, model updated since there wasn't any criticism
Well I haven't really had anything major going on with SU recently, haven't really had the time tbh. Upside to this though, I've now got enough money to consider getting a new pc, so hopefully I'll be able to run SU a bit better then. Also atm I'm kinda lacking inspiration since my mind is so messed up from night shifts I can't really think straight, so any ideas for something to do would be appreciated
