    [talk] Using Ruby Modules
    33 Posts 6 Posters 31.7k Views 6 Watching
    • Dan RathbunD
      Dan Rathbun
      @jessejames said:
      Well thats true because Ruby does not have Python's import mechanism. ... You just import what you need into the main script namespace. Anyway (back to Ruby) Could we somehow emulate import?
      Hell yeah...!
      The same way Google does the rbs import but without decryption.
      I was going to name the method ".parrot" and add it to module Kernel, that way it would be global.
      I'm willing to take suggestions for alternate names, if parrot sounds too silly. (Be sure to check the methodname index at: http://www.ruby-doc.org/core/ to both be Rubyish and not use name(s) that are traditional for some other action, like "inject" and "insert" which are used for Enumerable object methods like Array.)
      But basically you just open a file and read it into a string object.
      Then pass it to eval (or module_eval or class_eval,) within the calling context (aka scope.)
      There are a few search & replace tricks (ie, FILE, etc.) that need to be done before the eval, to simulate a normal load. But really it's not that complex, and wouldn't be that long of a method.
      There's also a 2nd argument to eval that allows the imported script block to be evaluated within any scope if you pass a binding.
      I'm not here much anymore.
      • Dan RathbunD
        Dan Rathbun
        I said before we need a style guide. Actually first we need a proper intro tutorial aimed directly at the SketchUp Ruby programmer.
        Well .. the forum [info] and [sticky links] posts are really a stop-gap, quick and dirty means. Temporary at best. (We can have only so many sticky threads.)
        There is Tutorial Page Space here at SketchUcation:
        http://www.sketchucation.com/tutorialsa/
        (A couple Ruby scripting Tutorials in the Advanced "classroom.")
        And a dedicated Tutorials Forum:
        http://forums.sketchucation.com/viewtopic.php?f=18&t=8767#p52652
        ..with a Ruby Tutorials "chapter"
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=8767#p52665
        (and a whoppin' total of 2 posts.)
        • Dan RathbunD
          Dan Rathbun
          @jessejames said:
          Anyway the real reason i replied is because i would for you and I to create a nice WORKING example of the very nested module system you are referring to. And what better example to use than all the script in the default SketchUp examples folder...
          1. animation.rb
          2. attributes.rb
          3. box.rb
          4. contextmenu.rb
          5. linetool.rb
          6. selection.rb
          I already did a quick and dirty "wrapping" of the box.rb example (I might change the namespace names if I was to go at it again.) I had to do it quick because some people wanted to use the example and it didn't work because (why else?) it was running in the ObjectSpace and it and the "make_pano_pm.rb" plugin (both by Google,) both defined a create_box method. The second redefined the first, so box.rb did not draw it's boxes. (What an example, but it serves as an example of clashing code.)
          I don't think I did much reformatting (I didn't want to change it too much, and I know I broke indent rules.)
          Plugins Forum: [Example] box.rb version 2.0.0
            That would have been useful if SU's loader for scrambed plugins allowed that.
            I ran into problems when I created an SketchupExtension that loaded an .rbs file - everything, got loaded within the SketchupExtension namespace. Had to use an unscrambled proxy loader to work around that.
              Yes - there used the many more - now they are moved into this sticky: http://forums.sketchucation.com/viewtopic.php?f=180&t=10142
              Unfortunately it's not obvious resource to find.
                jessejames
                Ah yes, the ol' multiplicity at work again! πŸ‘Š
                Multiplicity is the hobgoblin of learning recourses. People just give up (rightly so) if they have to search through mountains of dispersed data. We need to gather all the data available into one wiki page (or whatever) that will serve as a single "simple to use" resource for the noob.
                Always sleep with a loaded gun under your pillow!
                  jessejames
                  @dan rathbun said:
                  Hell yeah...!
                  Now you're speaking my language Dan! πŸ‘
                  Hmm, parrot is interesting. And lord knows i parrot off about Python all the time. However the word lacks an intuitive-ness for the action it implements. I don't think you'll find a better word than import.
                    I think there used to be a developer wiki - but I think I saw it when I first joined SCF. Can't remember or find it now. In any case it fell into disuse.
                    Jim did create an alternative to the official API docs, http://code.google.com/p/skx/wiki/ClassIndex one that we could edit ourselves. Which I find more useful than just posting comments and twiddling thumbs, waiting for it to be acknowledged.
                    Haven't had time to use or work on it, but it would be good if he had that, and a wiki at one joint location.
                    It has bothered me that so many resources are wedged in between all the questions and general discussions.
                    The forum is great for gathering knowledge, but no good at organizing it.
                      jessejames
                      Well my hats off to Jim although i looked over the doc and not much is there. I fear it will suffer the same fate as all the other docs and resourses -- a slow and agonizing death! Multiplicity and mediocrity are very prevalent in the SketchUp Ruby world today. We mush reign in this madness! Too long have stood idle whist the castle is laid siege. We need to yelling with a united voice daily...
                      Google we need an official Script Repository!
                      Google we need and official tut that can be edited by members!
                      Google we need official docs that can be edited by members!
                      ... and we need all this information centralized yesterday!
                      Is this comment directed at Moi? πŸ˜„
                      Wrong! We cannot keep up this multiplicity. We must force Google to do what is needed. You just wasting you time creating more sites that no eyes will see. If you have a suitcase full of money buried in the back yard but you forgot where you buried it then you really DON'T have a suitcase full of money do you?
                      Yes this too is a major deterrence to learning. Heck i was reading an announcement thread about a new script that had like 200 replies and many revisions to the script. After an hour of reading i just gave up. I could not even find the proper version in all the noise. It would be wise to allow an "announcer" to edit the very first post of his "announcement" indefinitely so he could update links to future versions or add more comments TO THE VERY FIRST POST INSTEAD STINGING INFOMATION THROUGHOUT 200 POSTS 😲 . Let the following string of thread[2..-1] answer users questions but keep the first post as an editable informational only post.
                      πŸ‘ πŸ‘
                        No - it was directed at the current system of the API docs. We have a long thread here with comments on the API docs. Which on occasion is read by Googlers which in turn make adjustments.
                        That was before they added the comment system on the API pages - where it was requested me made comments there. But response to our comments has been slow.
                        There's a problem here - we don't have much power to force Google to do anything. If one can make Google buy into an idea - it's something that'd be a dreadfully slow process. Doing it yourself seem to be the only thing to get stuff done.
                        All though I agree that there's no point in yet another site/resource project falling into disarray.
                        However, I do believe that our previous attempts might have been a bit over-ambitious. Starting of with a too big of a task. Starting off with something smaller and evolve that could work better.
                        What plugin was that? People can edit their own posts.
                        The normal convention here at SCF is that the first post contains the updated most recent version of the script. Pretty much all topics for plugins adhere to that.
                        A more recent discussion has been in regard to the visibility of the download link - a Download button graphic making it easier to spot the download link. Something some authors already use and something I will be updating my posts with.
                        • Dan RathbunD
                          Dan Rathbun
                          Wow this thread is all over the place.. but interesting.
                          Jim's Wiki API is an experiement. I played with one of the ConstructionPoint class, and came to the conclusion, it's just way too labor intensive. It relies too much on people following a set of style rules.
                          I did an automtic API some years ago using CSV data and HTML Tabular Data Controls that auto generated the API page. I wasn't satisfied (although it worked.) I always wished to update it to XML. Add the entries into the xml would be via a webform (check boxes, cut&paste boxes, etc.) then later on the API doc (either web or CHM,) would be generated from the XML (however PHP, RUBY take your pick.)
                          Editing would be similar, the method data would be displayed in an edit form.
                          Anyway the style of the API pages would be controlled thru CSS, and all pages, classes, would be displayed the same.
                          • Dan RathbunD
                            Dan Rathbun
                            @morgan74 said:
                            Thanks Dan for this interesting topic. I was rewriting all my plugin's code when I saw this thread.
                            So the only thing I need to do to follow you is adding a "TOP_LEVEL" namespace to my modules.
                            But I have a question about adding methods to Sketchup classes :
                            I want to add a method to "Geom::Point3d", how can I use a special name ??
                            Here my current code :
                            > class Geom;;Point3d
                            >   def myFirstMethod
                            >     return(self.z*self.z)
                            >   end
                            > end
                            • Dan RathbunD
                              Dan Rathbun
                              > > class Geom;;Point3d
                              > >   def myFirstMethod
                              > >   end
                              > > end
                              It's impossible to be 100% sure no one else implements a method of the same name as your when you extend a shared module/class. But if you for instance prefix with your initials you decrease the likely hood that your method is overwritten.
                              Personally I don't extend the base Ruby and SketchUp classes because of the potential of name conflict. (Doesn't look as good - but it's safe.)
                                jessejames
                                Hmm, i was wondering when\if these posts would get moved.
                                PS: if you guys need a easier hint to the 1264 thing send me a PM. I fear i may have set the bar too high! πŸ’š
                                • Dan RathbunD
                                  Dan Rathbun
                                  This is an example of people who just cannot follow instructions. (sigh!) And then compound the error, by posting AGAIN, to acknowledge he sould not have posted there. (I shake my head in wonder..)
                                  It just shows that the forum environment is not so good for tutorials. Even the dedicated Tutorials Forum allows reply posts. I wish we could lock our own topics such as my [info] thread.
                                  But at least I tried...
                                  • Dan RathbunD
                                    Dan Rathbun
                                    1. animation.rb
                                    2. attributes.rb
                                    3. box.rb
                                    4. contextmenu.rb
                                    5. linetool.rb
                                    6. selection.rb
                                    Well yes I have been thinking about this.. but there are isssues.
                                    1. I just know that some newbies are going to tweek, change and update the examples, without changing the namespaces. The examples need to be in some 'Google' namespace, as opposed to MY examples which would be in my namespace. These 'examples' I don't think would be sub-namspaced under the normal "Plugin" namespace ::PINE, but in an ::EXAMPLE namespace. (Most are not "true" plugins anyhow, more like code snippets we are supposed to paste into our own plugins.) I haven't yet finalized what the proper organized namespace trees should be, but I'm semi-close to publishing a proposed "Community Standard."
                                    2. I have a huge list of my own projects I'm working on, or want to work on. (Some I've had to put aside, because they will rely on another project; or there's some bug in the API; or some missing feature not in the API that I will need. Anyway I either must wait until the API is updated, or create the functionality myself, propbably in C code.)
                                    3. There is an issue of compensation. These scripts are the intellectual property of Google, although they have released them under terms close to the language of the MIT License. Yes, I would be helping everyone in the community, but ALSO, one of the largest software corporations in the world. I need income! I have bills, and am not employed. (The unemplyment rate here on the Florida Space Coast, is high and getting higher with the end of the Space Shuttle program.) I'd love to whip the Examples into shape. I'd love to correct every typo and missing argument description, etc within the API documents. But technical documentation is what I do for a living, and I feel that I should be paid, even if in the short term it's a discount payrate (I'm not greedy, and my expenses are low.)
                                    @jessejames said:
                                    The bad thing about a system like this is the fact that if people find it too confusing to implement they will just choose to be lazy instead -- and the last thing we need to do is help spread MORE laziness around this group! I always say a working example is the key to understanding systems like this.
                                    True.. but there is also immense value in this. Last week one of the newbies I've been mentoring, PM'd me to ask for just this same thing. He wished me to provide him with a working skeleton of a tool plugin, into which he could paste his Tool class definition. (He even put a "## my tool code goes here" comment in his outline.)
                                    I spent three 10 hour days putting together just such a skeleton, and then realized I could not keep doing these things. That is between 500-1000 dollars of work (depending on what you think the payrate should be.) I took a break, went on a walk, thought about it, and came to the conclusion that I need to genericize the code, AND implement it as a "Plugin Builder Wizard" (which would be a plugin itself.) Think about how a Software Installation Wizard works, and you'll get the idea. Sucessive forms, with choice controls (checkboxes, etc.) and the person would either use an "import file pathname" box (with a 'Browse' button of course,) OR a "paste code here textarea." (Their choice.)
                                    So that's what I'm going to do with that project. But this cannot be free. I must have some kind of income from it.
                                    Either individual license, or some entity, (commercial or benevolent,) needs to purchase it from me, for the salary-time I've put into it.
                                    To complicate it a bit... I had to stop work on that, in order to resume my project to update the Sketchup Extension class as the "wizard" project will require it. I had already revised the Extension class to v1.1.0 back in January, and have been running it since (but did not release it.) It was only a few simple, minor changes.
                                    This update will be v2.0.0, and will have major changes, BUT also be BACKWARD COMPATIBLE with v1.0.0 (the original un-numbered Google release.)
                                    In addition I have some features I want to put in there, but they may need to wait for v3.0.0 or I'll never get it (or my other projects) finished.
                                    This also has the same compensation issues like I had stated above. How to release it? I will have 2 weeks (say 100 hours invested in v2.0.0,) and really need to be paid for this somehow. Either Google buys it and they release it, OR I need to convince users and developers that it's a good thing and pay some small token license fee. (Somewhere between one and five dollars US.)
                                      jessejames
                                      @dan rathbun said:
                                      Well yes I have been thinking about this.. but there are isssues. [...snip...]
                                      Ok Dan, let me make sure i follow you. I going to summarize your post and tell me if i am correct...?
                                      You want to create a "namespace manager" plugin (for lack of better term?) that works like a typical installation wizard. A user of such plugin would create a script by writing code in a "toplevel" manner without worring about modules or even nested modules. THEN they would run the plugin which would auto wrap their code into a proper nesting of module namespaces with their name being the toplevel module space. So in the end, the scripter no longer has to worry about the confusing aspects of Ruby modules and can concentrate on writing usable code that will be safe from invading outside namespaces.
                                      Is this correct?
                                      β˜€
                                      Hey, this plugin may even work nicely on a nested folder structure of scripts in which to base it's "module nesting" on..? You create a toplevel folder with your name, then maybe a tools folder full of tools, then maybe a lib folder, and on and and on.
                                        jessejames
                                        Hmm, i'll give a clue... the sum of his name is 1264. I'll let the advanced readers decifer the meaning 😎
                                        PS: I'm just glad it was not 666 πŸ˜†
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Yes.. and NO. There would be a "Coder's Config" feature (dialog) where they set up defaults (name, company, Location, TopLevel Namespace, etc. etc.) but these defaults should be able to be overriden on a project basis, if say they were doing contract work for other than themselves (ie: another company.) So yes.. there ARE project management aspects.
                                          And there would be Namespace Managemnt aspects, as some prolific coders are likely to subdivide their namespace into Catagorical subnamespaces (Anim, Export, Import, Report, Tool, Utility, Widget, whatever and however they'd want to organize their products.)
                                          But it is really a "Proper Plugin Code Generator and Functionality Adder."
                                          Yes.. but with flexibility. (I'll just say that [for future possibilites,] they'll have the option of nesting their TopLevel namespace within other namespaces, even nested ones.)
                                          More important. What I was speaking of in the previous post... is much more than a simple wrapper. It is specifically aimed at Tool class, and auto generates Extension loader scripts, optional Smustard Compatible Menu Scripts, Normal Menu Scripts, Toolbar Scripts, etc. It more than just "wraps" the raw tool class code, it also adds management functions, auto unload functions. It takes care of "doing it the correct AND safe way", ie it takes over the setup of the menu / toolbar command, so it's done correctly without creating a zillion uneeded tool objects every time the menu is clicked, etc. It sets things up so a coder can "publish" a safe tool call for other poeple to call (from another script, or a custom toolbar, etc.)
                                          I suppose it could also work for normal non-plugins like Importers / Exporters etc. I'll just need to keep that in mind.
                                          More exactly: "code that will NOT invade outside namespaces." (Meaning that crap scripts can still poop on the Objectspace, but it won't then do much more than waste memory. I still hate poop methods in Object getting inherited by every module and class.)
                                          You are actually describing another item on my todo list. The "wrapper". (A linear command script really does not need a wizard; I've already shown in the forum how to put a couple of module blocks around them.) There's the possibility someone like you and I want to autowrap all code in our plugins folder, rather than manually edit every script we download.
                                          And.. a proplific coder, may want a batch utility to autowrap all his project folders, rather than do it manually.
                                          I may be speaking of several separate utilities here.
                                          Yea you speak of a project folder and it's subfolders, such as we'd use with MS Visual Studio. They would contain the "raw" code snippets, and the Wizard would output the "distro" files in folders beneath the project's "distro" folder (which has a "plugins" folder.) Any file (a Extension registration rb,) that needs to go in the Plugins folder, would be put in the "distro/plugins" folder itself. From there it's manual copy to the real plugins folder (for your own testing,) or zip the fake "distro/plugins" folder for distribution/posting.
                                          • Dan RathbunD
                                            Dan Rathbun
                                            Of course the next campaign.. when we get everyone to wrap there code.
                                            Is to get them to change their $vars to @@vars.
                                            Like $my_specific_plugin_menu_is_loaded
