    [Request] Draw lines,as if they were extruded with a circle.
    6 Posts 3 Posters 812 Views 3 Watching
    • N Offline
      nilaul
      Draw thick lines, as if they were extruded with a circle. Is there a plugin that allows you to do this?
        Hi Nilaul and welcome!
        TIG has a 2D Tools plugin that is supposed to do such things (I never really need them so never tried myself).
        • Didier BurD Offline
          Didier Bur
          This one may help too: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=226
          DB
            Hi Didier,
            The Ruby Depot is down again it seems. I get this error:
            Warning; mysql_connect() [function.mysql-connect]; Can't connect to MySQL server on 'localhost' (10055) in C;\Program Files\xampp\htdocs\rubylibrarydepot\DBLink.php on line 27
            Fatal error; Uncaught exception 'Exception' with message 'Dababase connection failed.' in C;\Program Files\xampp\htdocs\rubylibrarydepot\DBLink.php;35 Stack trace; #0 C;\Program Files\xampp\htdocs\rubylibrarydepot\DBLink.php(19); DBLink;;connect() #1 C;\Program Files\xampp\htdocs\rubylibrarydepot\Site.php(109); DBLink;;getConnection() #2 C;\Program Files\xampp\htdocs\rubylibrarydepot\lang\lang_en.php(89); Site;;get_count_objects_db('plugins') #3 C;\Program Files\xampp\htdocs\rubylibrarydepot\Lang.php(60); require_once('C;\Program File...') #4 C;\Program Files\xampp\htdocs\rubylibrarydepot\Display.php(36); Lang;;loadlanguage() #5 C;\Program Files\xampp\htdocs\rubylibrarydepot\index.php(3); Display;;init() #6 {main} thrown in C;\Program Files\xampp\htdocs\rubylibrarydepot\DBLink.php on line 35
              Didier Bur
              Hi Gaeius,
              Grrrrr πŸŽ‰
              Not at the office now . Will reoot the server tomorrow morning .
              DB
                πŸ‘
