    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.3m Views 329 Watching
    • Whiteowl77W
      Whiteowl77
      Interesting tool.
      I am using this "Shape bender" Tool in order to create Curved 3D Text in SketchUp, that I can wrap around a cylinder, and use for LOGO purposes. Combined with the "Intersect w/ Model" Tool, and Vray and IDX software - this can really do some remarkable stuff.
      Glad to help out anybody who gets stuck with this tool or any 3D Modeling Problems!
      Andrew Telker, LEED AP, ECO-Designer
      http://www.telkerdesign.com
      • Chris FullmerC
        Great Andrew, glad you like the plugin so much. Thanks for the offer to give assistance when people need it. They generally just ask here on the forum, since that is what its here for. So if someone asks a question you feel like you can answer, we're always glad for the help around here. Thanks for the offer,
          August
          Hi arjunmax09,
          @arjunmax09 said:
          ... is there a way to increase the segments of the bended object?...
          Watching your video, there are two issues that might be related to your problem.
          If you look carefully at the construction lines the Shape Benders shows you (pause at about 00:06 in the video), it's clear that the dividing lines of the bending object are based on the segments in the target curve. Your target curve has 12 segments.
          So, first, if you want the bending object to bend in more places, draw a target curve with more segments.
          You can change the number of segments in a circle or an arc by typing a number (appears in the ODW/Measurements Box) right after you pick the tool. If you are drawing an arc, the number represents the number of segments in your current arc, not the number of segments if the arc were a full circle. Press Return/Enter to set the number.
          Second, your guide line is much longer than your bending shape, so the shape only gets bent along part of your target curve. Only six full segments and two partial segments are being used to match to the bending object. There is a section at each end of the target curve that does not get the shape applied because those are the areas that have guideline but no shape.
          If that's clear, great. If that's confusing, try thinking of it this way:
          It works as if the Shape Bender picks up the object and the guide line at the same time and then bends, stretches, or shrinks the guide line to fit the target curve, bending, stretching, or shrinking the object along with whatever it does to get the guide line to fit onto the target curve. Depending on the shape of the target curve, the size of the bending object, and the distance between the guide line and the bending object, some parts of the object may be compressed while other parts may be stretched. But regardless of stretching or compressing of the object, one segment of the bent guide line is created for each segment of the target curve.
          I hope this helps,
          August
          β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
          [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
          • G
            GilliganU
            I suspect it's an issue of which way your lettering is rotated.
            My text test case is quite similar to your bar example, except in my case, the ends of the curved bar are parallel to the original bar! here is a photo:
            http://z.gillie.us/gillie/shapebender Please click the link
            (sorry, my site has hotlink protection, so in-lineing won't work)
            Also, the bad bent cylinder is there, too. The curve is where the cylinder was supposed to be bent to.
            Maybe you'll find time to download my test case, soon.
            Gilligan
            • T
              twistedtwin
              I just downloaded Shape bender and, after the "unzipping",I dragged the "clf shape bender" folder and the "clf shape bender loader.rb" into the plug ins folder on my mac.
              When I launch SU a window appears saying:
              "Error loading File clf shape bender loader.rb no such file to load--progressbar.rb"
              I tried the process a few times but the result doesn't change.
              Any suggestions??
              • GaieusG
                Hi TT and welcome!
                Yes, this (and some other) plugins need this one, too. Download and install it the same way from here
                http://www.smustard.com/script/ProgressBar
                • T
                  twistedtwin
                  Thank you Gaieus!!!!
                  I must have spent a good hour messing about with the plug ins....I should have asked sooner!! πŸ˜’
                  Everything works fine now...and it's brilliant!!!
                  Thanks again πŸ‘
                  • GaieusG
                    Cool. Next time DO ask!
                    πŸ˜„
                    • Chris FullmerC
                      Gilligan
                      Hi Gillian, A few things I noted. It looks like you are modeling sideways. In SU, the red and gree axis form the ground. The blus should face upwards. Unless you modified that purposely, it looks you are working sideways, and that will mess up shapebender for sure.
                      The other thing it could be is possibly the start and end edges do not line up correctly. If you attach the model to this forum I'll take a look at it and see if I can get it to work. Thanks,
                      • G
                        GilliganU
                        Thanks, Chris! Rotating everything so that the blue axis is up solved the problem. I've only used ShetchUp for a few hours and I'm not very familiar with many of it's conventions. I'm checking out several CAD programs to see which best meets my needs. It does seem curious, to me, that if the shape bender can follow arbitrary lines in 3D, why the orientation of the model matters.
                        I can still get it to fail by hitting the up or down arrows once or twice, after the first bent shape appears, and before return. I have uploaded picture and the test case on my website: http://z.gillie.us/shapebender/ IT's the third picture: Bent Text Two. Though teh problem seems easy enough to duplicate, the web page includes a link to a SketchUp file, under the image.
                        Gilligan
                          August
                          Hi Gillian,
                          I suspect that you don't have a complete mental model of what and how Shape Bender is doing what it does, and that is the source of your confusion both in conceptualizing how to apply it to your task and your problems with using it.
                          I downloaded your SKP file and attempted what you had apparently been attempting.
                          (For clarity I try to use consistent terminology: Source Object, Guide Line, Target Curve, and Result Group. That way, if they are shortened to Object, Line, Curve, and Group, it can still be unambiguous.)
                          I tried to bend the undistorted "Enter Text" as the Source Object using the line immediately under it as the Guide Line and the curved line nearest to it as the Target Curve. Here is the result, before pressing Return to accept it:
                          [attachment=0:3212bbj0]<!-- ia0 -->Trying to duplicate bentText2<!-- ia0 -->[/attachment:3212bbj0]
                          (I have the Shape Bender Toolbar floating in the middle of the drawing area.)
                          As you might infer from the image, I had no problems. I opened your file, I clicked the Source Object, I clicked the tool button in the toolbar, I clicked the Guide Line, I clicked the Target Curve, I captured the image. Note that Start and End are still indicated for both the Guide Line and the Target Curve and the proposed Result Group is still green because I have not pressed Return yet.
                          Here are a couple of pieces I wrote a while back that might help:
                          Feb 26, 2010, Page 25 of this thread.
                          Shape Bender slices up the Original Object with vertical slices, according to how many segments there are in the Target Curve. One of the keys to predicting how it is going to work is that it will keep those slice faces vertical. It will rotate them in the Red-Green plane, but the slices will stay vertical.
                          The result is that for vertical curves Shape Bender projects the shape onto the curve vertically, for horizontal curves, it fans out and compresses, which is typically what you expect.
                          Apr 27, 2010, Page 30 of this thread.
                          The above description of how Shape Bender works provides the answer to your question:
                          @gilliganu said:
                          ... It does seem curious, to me, that if the shape bender can follow arbitrary lines in 3D, why the orientation of the model matters. ...
                          The orientation of the model is critically important because that determines how the Source Object gets sliced up so that it can be bent. Most problems with Shape Bender seem to come from people assuming how an object "ought" to bend that unconsciously includes internal stretching/shrinking that is does not match how Shape Bender slices up the Source Object. That is how the orientation of the model matters.
                          Unfortunately, right now the only "manual" for Shape Bender is this discussion thread, and right now that is 532 posts in 36 pages. A while back I offered to Chris that I would collect the best stuff from the thread and edit it into a manual, but I haven't gotten to it yet. I hope the above bits aid in clarifying things for you. If not, there's probably something from someone else in here somewhere (the Search This Topic tool at the top of the page may be of use).
                          On that topic, I was unable to duplicate your bending of the text, where part of the final "t" went off at an angle. It looks a lot like the trouble you were having with the cylinder earlier. If you can duplicate the problem, I would like to know what you did, because if I ever put that SB manual together, it would be useful to know what people have trouble with and what they are thinking when they approach this tool "cold".
                          I hope this helps,
                          August
                          • I
                            InterArchi
                            Hello Chris, Hello everybody , I'm new in this forum, and the first plugin I wanted to learn is the "" Shape Bender '' but I cant find the link for downloading the " NEWEST VERSION of the plugin, Would you please upload a link for me please ?
                            Cause the first version seems to be not working for me
                            • GaieusG
                              Hi hichem and welcome!
                              Indeed the one attached to the first post is the newest version. This plugin is a bit tricky to use (thus is is still called "Beta"). Are you sure you are doing everything right (or installed the script correctly)?
                              • G
                                GilliganU
                                @august said:
                                Hi Gillian,
                                That does explain a few things. My erroneous assumption was that shape bender sliced up the Source Object by planes perpendicular to the reference line. Which is only true if the Source Object is oriented appropriately. It would be nice if the required orientation was documented.
                                I hope this helps,
                                August
                                The stretched out "t" was generated by hitting the down arrow, just after the 'proposed' bent object is displayed, and before the return key. The up arrow works fine, by swapping the ends of the reference object relative to the reference line before bending it. In this case, the text will read backwards. I can't recall what the down arrow is supposed to do, though I remember reading about it somewhere. It's not on the help menu.
                                It is unfortunate that many programmers don't feel the need to document their code. It makes it very difficult for others to use it. I write a fair bit of code myself and I always document it. It is often just for myself, as I often forget rarely used features a few years later. In the programmers defense, many users refuse to read documentation when it is provided. Many won't even read a single line explaining what to put in a box on a web form! An issue I've faced many times.
                                Gilligan
                                  August
                                  Hi Gilligan,
                                  My apologies, I just discovered I've been leaving out the second G in your name.
                                  August
                                  • I
                                    InterArchi
                                    Thanks brother for answering me, I guess I have fixed that out, the only problem is that I didnt copy the Jpeg files into the directory of plugins πŸ˜’ thus, the plugin didnt work properly any way thank you very much for your help,
                                    If I need anything arround, I will call for your help, I have just discovered this forum and I'm really learning from you guys I do really appreciate your efforts πŸ˜‰
                                    • Chris FullmerC
                                      Good, glad you got it working.
                                      The main problem with this plugin is that it was written by a no good hack of a programmer. Everytime this plugin works it surprises me. I love this plugin and I'm certainly proud of it. But it could use a major re-writing to get it to be more stable and more versatile.
                                      Thanks for using it,
                                        Allen Brown
                                        Hey Guys,
                                        Sorry if this has been covered already, but I am a complete noob with SU, and have never used scripts.
                                        First of all, I am using the free version 7.0.10247.
                                        I first downloaded progressbar.rb. This is where my first problem starts; I unzipped it to my desktop, but I don't know what to do with it from there. Double clicking on it brings up a window asking me what program to use to open it.
                                        Can someone point me in the right direction?
                                        Thanks,
                                        Allen
                                          Hi Allen,
                                          First off, welcome to SCF!
                                          I noticed you're using SU 7.0.1, Google released 7.1 awhile back it's alot faster, give it a go..
                                          As for plugins, Gaieus posted a little tutorial here
                                          Basically all plugins are placed in your plugins folder...
                                          Program Files>Google>Google Sketchup 7>Plugins
                                            Allen Brown
                                            Thanks Rich. I got both the progress bar rb & the shape bender rb's copied into my plugins folder. It appears to have worked somewhat, because I have the shape bender tool on my toolbar, and under the plugin menu I have the chris fulmer tools. However, I don't see anything about the progress bar rb in the plugin menu, should I?
                                            Anyways, I create some 3d letters, click the shape bender tool, and I would expect to see "Please select a single line..." down at the bottom of my screen, but I get nothing. It's as if it doesn't really activate. I also tried by going through the plugin menu, but I get the same behavior.
                                            Any ideas what I'm doing wrong?
                                            BTW, I did try exploding the letters, then shift selecting, right click and making "Component", but still the same.
                                            Thanks,
                                            Allen
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 63
                                            • 64
                                            • 27 / 64
