    Run batch file from ruby as admistrator
    7 Posts 2 Posters 4.5k Views 2 Watching
      simonstaton
      I am running a batch file from ruby using:
      ge=UI.openURL(Sketchup.find_support_file('')+"/registergoogleearthcmd.cmd")
      inside the batch file is the following:
      "C:\Users\Simon\Documents\Action Design Your Own v2\Action 3D\client\googleearth.exe" /regserver
      however when I run sketchup and the batch file is loaded it says it needs to be run as administrator now this command works fine if I load up cmd as admin and manually typing it in it goes straight through.
      So my question is how can I run this from ruby as an administrator?
      Simon
      • Dan RathbunD
        Dan Rathbun
        What would be the point of having an Operating System Security if any script was allowed to run with Administrative Rights?
        Oh wait... I do remember MS-DOS πŸ˜†
        I'm not here much anymore.
          simonstaton
          hmm so there is no way of doing this? I have updated my script with the following:
          tmp_cmd="My_tmp_file_"+Time.now.to_i.to_s+".cmd"
          cmd_path="C;/Temp/"+tmp_cmd
          cmd_line="\""+Sketchup.find_support_file('')+"/client/googleearth.exe\" /regserver\nexit"
          cmd=File.new(cmd_path, "w")
          cmd.puts(cmd_line)
          cmd.close
          UI.openURL(cmd_path)
          sleep(1)
          File.delete(cmd_path)
          if I cant run as admin is there any other way or registering google earths location outside of its default through command line or ruby?
          Simon
          • Dan RathbunD
            Dan Rathbun
            You'd need to use the runas.exe utility.
            It's in the Windows/system32 folder, so is available in the PATH.
            Open a CMD window, and type:
            %(#004000)[**runas /?**]
            for parameter information.
            For more info, do a search at MSDN
              simonstaton
              dont worry solved I just need to right click sketchup and run as administrator
              • Dan RathbunD
                Dan Rathbun
                Manual? I could have told you that!
                You asked how to do it with a batchfile... πŸ˜’
                  simonstaton
                  yes I know, but that easiest solution slipped through my hands 😲
