    Run batch file from ruby as admistrator
    7 Posts 2 Posters 4.2k Views 2 Watching
      simonstaton
      I am running a batch file from ruby using:
      ge=UI.openURL(Sketchup.find_support_file('')+"/registergoogleearthcmd.cmd")
      inside the batch file is the following:
      "C:\Users\Simon\Documents\Action Design Your Own v2\Action 3D\client\googleearth.exe" /regserver
      however when I run sketchup and the batch file is loaded it says it needs to be run as administrator now this command works fine if I load up cmd as admin and manually typing it in it goes straight through.
      So my question is how can I run this from ruby as an administrator?
      Simon
      • Dan RathbunD Offline
        Dan Rathbun
        What would be the point of having an Operating System Security if any script was allowed to run with Administrative Rights?
        Oh wait... I do remember MS-DOS πŸ˜†
        I'm not here much anymore.
          simonstaton
          hmm so there is no way of doing this? I have updated my script with the following:
          tmp_cmd="My_tmp_file_"+Time.now.to_i.to_s+".cmd"
          cmd_path="C;/Temp/"+tmp_cmd
          cmd_line="\""+Sketchup.find_support_file('')+"/client/googleearth.exe\" /regserver\nexit"
          cmd=File.new(cmd_path, "w")
          cmd.puts(cmd_line)
          cmd.close
          UI.openURL(cmd_path)
          sleep(1)
          File.delete(cmd_path)
          if I cant run as admin is there any other way or registering google earths location outside of its default through command line or ruby?
          Simon
            Dan Rathbun
            You'd need to use the runas.exe utility.
            It's in the Windows/system32 folder, so is available in the PATH.
            Open a CMD window, and type:
            %(#004000)[**runas /?**]
            for parameter information.
            For more info, do a search at MSDN
              simonstaton
              dont worry solved I just need to right click sketchup and run as administrator
                Dan Rathbun
                Manual? I could have told you that!
                You asked how to do it with a batchfile... πŸ˜’
                  simonstaton
                  yes I know, but that easiest solution slipped through my hands 😲
