    Ruby code: Random colored faces ?
    7 Posts 4 Posters 1.1k Views 4 Watching
      tomot
      Does anyone know if its possible to use the Rand function, or some other way to distribute random colors to a number of pushpull faces ?
      the present code below, defines a single color, I would like to add a random color routine ❓
      face = entities.add_face $xp0, $p1 ,$p4, $p0
      face.material= Sketchup;;Color.new(255, 255, 255)
      face.pushpull -($tthick+rand(20))
      The random color selection would paint faces similar to the pic, whose faces presently were individually painted.
      my plugins
      tomot
        face.material= Sketchup::Color.new( rand(255), rand(255), rand(255))
          tomot
          thanks thomthom for the quick reply; πŸŽ‰
          It works with the pushpull code below: however the faces are extruded below grade.
          face.pushpull $tthick
          Here the pushpull code extrudes the faces above grade, but the colors get trapped inside the extrusion.
          face.pushpull -$tthick
          is there a reverse statement I can use?
          my plugins
          tomot
            It sounds like the direction of your face isn't what it needs to be for you to get your expected result. Normally the direction of a face is controlled by the order of the vertices used to create the face - clockwise vs counter-clockwise. The exception is when the face is on the group plane, then SketchUp will force it face down.
            What you can try is, before you push-pull: face.reverse! - this will flip the face normal.
              tomot
              My error, I picked the order of the faces anticlockwise 😳
              my plugins
              tomot
                Maybe Chris Fullmer can help you πŸ˜‰
                • Didier BurD Offline
                  Didier Bur
                  You just have to reverse the order of points when creating the face, or to check the normal after creating it:
                  myface=Sketchup.active_model.entities.add_face(p1,p2,...pn)
                  # Default normal to blue (up)
                  face.reverse! if face.normal.z<0
                  πŸ’­
                  DB
