    R. Parker's WIP
    16 Posts 6 Posters 2.1k Views 6 Watching
      liam887
      instead of having the kraken motif as actual modeled geometry, you could probably save tens of thousands of polys by having it as a texture?
      good work so far tho!
      VISIT MY ONLINE GALLERY
        rogueparker
        Thanks liam for the idea, I never thought of that.
          liam887
          I think there is a way although I have no idea of how to do it, but have the texture with transparent parts to you can still see through the gaps it the motif even though its still a flat texture. No idea how you do it tho probs pretty simple.
            rogueparker
            It would be a picture done with alpha mask done as a png texture in gimp or photoshop. I'll try it out for larger parts, but when I do close up I kind of want the 3d detail.
            • TaffGochT Offline
              TaffGoch
              @rogueparker said:
              ...playing around with a concept I have in my head....
              That image got MY attention.
              So, what's the total geodesic concept?
              -Taff
              "Information is not knowledge." -- Albert Einstein
                kev_N
                the original image at the top looks a lot like what im trying to get with an old warehouse im modeling to put a bike into, would look good rendered? do you have a render engine/plug-in option? πŸ˜„
                  rogueparker
                  playing around with a concept I have in my head. geodesic plugin and the latice maker . Rendered in Kerkythea
                    rogueparker
                    futuristic memory drive concept for a fiction concept floating around in my head. I plan to post a few more views.
                    I used ixlrlxi/600v tutorial on this. I used gimp as opposed to ps so it didn't come out the same. I'm still toying with the settings.
                      rogueparker
                      more progress shots, heres what i have thus far assembled. I'm using the layer function which seems to be keeping the sluggishness under control.
                      I hope to have a render of the greenhouse like structure done by tonight.
                        rogueparker
                        Thanks dylan.
                        view 2 of my lower green house for my steam punk gas light fantasy city,
                        over 4000000 edges. I wont be able to add it into the final model until the end because it makes sketchup cry.
                        once again you can note the kraken motif.
                          rogueparker
                          Modeled the star case that goes from the loading docks to the main floor of the raised city. I added the kraken motif that I plan to repeat all over the city.
