    Twilight project
    42 Posts 12 Posters 8.2k Views 12 Watching
    • FrederikF
      Frederik
      Now all you need to do is to select all back-faces, right click and select "reverse face" et voilΓ‘ they should all face front...
      Please remember that you'll need to re-apply some materials and textures...
      I also saw that some of your faces don't have any material and/or texture applied at all...
      I suggest that you always apply a texture or a material to a face before rendering...
      For white surfaces, I recommend that you adjust the RGB values to i.e. 240, 240, 240...
      Real white (255, 255, 255) doesn't actually exist in real life and these can become too bright when you render them...
      Cheers
      Kim Frederik
      • jo-keJ
        jo-ke
        OK, Faces are reversed.
        Now I tried to adjust the light settings but I'm not really satisfied. I enclosed the scene for you to look for the settings.
        umbau-tw2.skp
        http://www.zz7.de
        • FrederikF
          Frederik
          OK... Took a quick look and made a few adjustments...
          1.) Removed some parts from the light components
          2.) Added a square mesh and applied an Emitter material using the TWR material editor
          3.) Adjusted the TWR spot-lights
          (Decreased the light strength from 5.000 to 2.000... Adjusted the Falloff to 120 degree and the HotSpot to 90 degree)
          I've attached the model below and hope you can learn from it... πŸ˜‰
          P.S. I also moved the floor up... You can see in your render that it's below the pillars and the walls...
          Please also be careful when placing the light components...
          I moved them up (app. 7,2mm) in order to prevent light leaks...
          P.P.S. Sorry about the TWR watermarks... I'm currently at the office and had to use a demo version of TWR... 😳 πŸ˜†
          umbau-tw2-1.skp
          Cheers
          Kim Frederik
          • jo-keJ
            jo-ke
            thank you so much. that helped a lot. I'm going to update the scene as soon as posible. I played a bit with the light. 2000 was to dark. I setted the light to 3000 and it looked great. Many things are clear to me now.
            http://www.zz7.de
            • N
              notareal
              turn on the 'monochrome' face style. the white ones are good, the light-blue ones are bad...
              When this kind of stuff is important in a model, I like to make the back-color a bright red... this can be changed in the styles/edit/faces dialog.
              Back faces are real killer for most renderers - you might get excessive reflection (like in Twilight or Kerkythea) or faces won't render all or they render black (it's all up to the engine). I don't know many render engines that can handle back faces, even in Thea they do matter, if one uses displacement or instancing brush. Making back faces to a strikingly different color, do help a lot. There is also a neat style for troubleshooting the scene.
              Second common problem I seen is that light sources do intersect with the geometry. Third common issue is the scene scale - when you use a physically based renderer, you must model in the correct scale.
              • FrederikF
                Frederik
                My pleasure... πŸ˜„
                πŸ˜• Eeehhh... You got me confused there for a second... πŸ˜†
                It's not 2000 (two thousand) but 2 point 000...
                A question... Can I ask you if you play games on the computer you're also using to render models with...??
                Reason for asking is simple... Since most of your renders seem over exposed, I tend to believe that your monitor is calibrated very dark...
                I've seen it before that users who are using the computer to both play games on and also render models always seem to be over exposed...
                Cheers
                Kim Frederik
                • jo-keJ
                  jo-ke
                  No I'm not gaming πŸ˜‰ but the lights in that room are really very strong. I will show a picture after the reconstruction is finshed.
                  http://www.zz7.de
                  • jo-keJ
                    jo-ke
                    here's the brand new render with perfect TWL- lights.
                    http://www.zz7.de
                    • jo-keJ
                      jo-ke
                      I just played around with the spotlights, edited the emitter and turned the direction. Now it comes pretty close to reality.
                      reality
                      http://www.zz7.de
                      • FrederikF
                        Frederik
                        Looks great, jo-ke...!
                        http://www.kerkythea.net/users/Frederik/Anim-Icons/thumbup.gif
                        To make it look even more real, you can exchange the spot-lights with a suitable IES-light...
                        Cheers
                        Kim Frederik
                        • jo-keJ
                          jo-ke
                          Yes IES would be the next lesson for me.
                          I'm loving it playing around with the lights. I've just added many flourescent lights and a new spotlight at the neightbour room.
                          here's another render...
                          http://www.zz7.de
                          • pyrolunaP
                            pyroluna
                            very nice, jo-ke! I always like to see such an improvement in a project! πŸ‘
                            • jo-keJ
                              jo-ke
                              We started this week with the reconstruction. I hope that we are finished at the end of the week.
                              http://www.zz7.de
                              • FrederikF
                                Frederik
                                Ooohhh... It's always great to see a project comming to life... πŸ‘
                                Cheers
                                Kim Frederik
                                • GaieusG
                                  Is that a render 😲 or a photo? πŸ˜‰
                                  • jo-keJ
                                    jo-ke
                                    and the next step is done
                                    http://www.zz7.de
                                    • jo-keJ
                                      jo-ke
                                      most of the work is finished. Next week, we're going to make the decoration.
                                      http://www.zz7.de
                                      • jo-keJ
                                        jo-ke
                                        nearly finished.
                                        reality
                                        SU- twilight render
                                        http://www.zz7.de
                                        • FrederikF
                                          Frederik
                                          OK... Although it's easy to see the difference between real and render, the render is really good...
                                          As you can see yourself, the fake emitter in the spot lights need to be increased in power and the floor also need some extra glossiness...
                                          Overall really nice to see this project evolving... πŸ˜„
                                          Cheers
                                          Kim Frederik
                                          • shuraS
                                            shura
                                            Right Frederik, I second that. It is very rare to see a whole project documented - I like to watch that.
                                            Good job jo-ke!
                                            • 2 / 3
