    Fast way to toggle visibility
    6 Posts 3 Posters 621 Views 3 Watching
    • N
      NewGuy
      I am looking for the fast possible way to toggle the visibility of a lot of individual groups or components. I am currently using Set (selection sets) to remember what objects need to be turned on and off, but it is still a little slow when I use the script below on a 100+ groups:
      $set.each { | item | item.visible = true }
      Any way to speed this process up? Or is this the only way?
      Thanks,
      NewGuy
        Jim
        Assign them a Layer and toggle the Layer?
          Are you using it within a model.start_operation with the second argument to true? (disable UI?)
          • N
            NewGuy
            "model.start_operation"
            That was it! Layers was my plan B. Thanks for the quick response.
              Note that using the second argument only works with SU7+
              I use this proxy method:
                def self.start_operation(name)
                  model = Sketchup.active_model
                  if Sketchup.version.split('.')[0].to_i >= 7
                    model.start_operation(name, true)
                  else
                    model.start_operation(name)
              • N
                NewGuy
                Good point.
