    Cutting windows hole plugin
    4 Posts 3 Posters 1.2k Views 3 Watching
      catherine
      cutting windows holes.
      i'm trying to use the pluging to make the component automatically making a hole in a 2 sided wall.
      I'm able to make the component, set points or the face but nothings happen when i put the window on the wall. the wall stays in 1 piece, and no hole is appearing. No setup window anywhere to set where to glue the window.
      i would like to know what's wrong, and
      • when creating the component, do we have to glue it on a selected plane and define to cut a hole already? (like glue vertically, per exemple)
      thank you so much!
      Catherine
        Have you a link for this plugin?
          catherine
          http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/em_edi_page.htm
          that's the Cutting_window.zip file
          thank you!
          • Didier BurD Offline
            Didier Bur
            No.
            Dropping the window in the wall doesn't automatically create the hole. Right-click on the window (or on a selection of windows) and select "Window and wall > Cut wall from window".
            See chapter 2 of the PDF, everything is in there πŸ˜‰
            DB
