    [Plugin] Slots 4 Tabs
    10 Posts 4 Posters 12.8k Views 4 Watching
      kyyu
      This plugin automatically makes mating slots for a part with tabs.
      Copyright(C) 2010, kyyu
      All Rights Reserved
      Permission to use, copy, modify, and distribute this software for any purpose
      and without fee is hereby granted, provided this notice appears in any copies.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      Name: Slots 4 Tabs
      Version: 1.1
      SU Version: 7.0
      Date: 06-02-2010
      Description: Automatically makes mating slots for a tabbed part
      Usage: Select both the parts (each grouped) and right click context menu ( [kyyu]/Slots 4 Tabs )
      * Plugin will automatically detect which part is which
      * Parts should be place in proper perpendicular, intersecting position
      * Parts are assumed to be flat plates, thickness same as tab height
      * Tab height needs to match expected thickness exactly (default is 0.25 inch)
      * How to change thickness value:
      1) Type for example "$kyyu_s4t = 0.25 or 3.mm" into the Ruby Console. Will be good for entire SU session.
      2) Or change the default permanently, a few lines down in the code.
      * Plugin automatically defaults to the move tool when done. You can comment this out, if not wanted.
      History:
      1.0 (05-27-2010) - first version
      1.1 (06-02-2010) - fixed some metric bugs
      =end
      [flash=554,406:wn4hl47m]http://www.youtube.com/v/zIjcqTf-hxI[/flash:wn4hl47m]
      New version 1.1 (fixed some metric bugs)
      ky_Slots_4_Tabs (v1.1).rb
      Slots_4_Tabs (0.25 inch test file).skp
      Slots_4_Tabs (0.125 inch test file).skp
      Slots_4_Tabs (3mm test file).skp
      -Kwok
      • X Offline
        xrok1
        thats pretty cool! if you plan on taking this further i think automatically generating tabs of predefined sizes on clicked edge and tolerances (gaps) between slots and tabs would be excellent additions to this plugin. πŸ˜„
          kyyu
          Yes, I agree, auto tabs would be cool. So little time, and some many plugins to write. πŸ˜‰ -Kwok
          • E Offline
            eco_artbarn
            hey kwok,
            great idea
            though when i do all the steps no slots are created
            any suggestions?
            cheers
              kyyu
              @eco_artbarn said:
              hey kwok,
              great idea
              any suggestions?
              cheers
              Hi. I was going to ask if they were groups, but I just checked and you would have gotten an error message. If you can post a sample file, I will take a look at it. Or you can give my test file a try:
              Make Slot test_v1.skp
              -Kwok
              • E Offline
                eco_artbarn
                hi i have tried yours and it works great
                but my file does not, i have tried typing in and changing to decimal in ruby but i get this:
                $kyyu_s4t = 3.mm
                0.118110236220472
                Error: #<ArgumentError: comparison of Length with nil failed>
                C:/PROGRA~1/Google/GOOGLE~2/Plugins/ky_Slots_4_Tabs (v1.0).rb:35:in ==' C:/PROGRA~1/Google/GOOGLE~2/Plugins/ky_Slots_4_Tabs (v1.0).rb:35:in kyyu_Slots_4_Tabs'
                C:/PROGRA~1/Google/GOOGLE~2/Plugins/ky_Slots_4_Tabs (v1.0).rb:250
                C:/PROGRA~1/Google/GOOGLE~2/Plugins/ky_Slots_4_Tabs (v1.0).rb:250:in `call'
                i tried changing it in the plugin in notepad but it didn't make any difference
                attached is my file, maybe i am missing some simple step?
                i need to work to 3mm
                cheers ashley
                slots 1.skp
                  kyyu
                  Hi eco_artbarn,
                  Ok, I've fixed it and should now be working for metric. The 1st post has been updated with v1.1. This plugin is based on a whole string of assumptions and metric just doesn't work 100% of the time. But the bad news is your parts have a problem, I think. At least on my computer. It's the 1st time I have seen it massively fail and deform the part, instead of just giving an error message and stopping. Using 3.mm worked on my test 3 mm file, but not on yours. For some strange reason your 3mm is slightly different than what my computer draws. See the picture below. My coversion is exactly what the goggle calculator shows. Yours is not. If I type in exactly $kyyu_s4t = 0.11817322834643, then your part works. Otherwise massive failure. Just hit undo. I've stepped through it, but have no clue. One second it is fine and then next step, the faces are fractured and many bits gone. Possibly, your computer will not have a problem, if it's all consistant there.
                  Oh, if you want to measure the edge yourself, just select the edge and type this into the ruby console "Sketchup.active_model.selection[0].length"
                  -Kwok
                  • E Offline
                    eco_artbarn
                    hi kwok
                    well done
                    no idea about my measurements being off on my computer, but that did work now by putting
                    $kyyu_s4t = 3.mm
                    can i just open up the plugin in note pad and change that line to make it do that permanently?
                    many thanks for your help.
                    now i just need to try and unfold it all to try and create some 2d files to laser cut using the finger joints.
                    we never seem able to match up all 6 sides of an object when using a line cutting programm
                    big thanks
                      kyyu
                      @eco_artbarn said:
                      $kyyu_s4t = 3.mm
                      Cool! Glad it's working. πŸ˜„ Yes, you can just edit it, like a text file. -Kwok
                      • O Offline
                        OregonCoastDad
                        Hello,
                        I'm planning to download and play with this. I was wondering will it work on curved edges and parts?
                        Brock
