    API Docs Comments
    40 Posts 8 Posters 5.5k Views 8 Watching
      Jim
      As an experiment, I used the skx project wiki to fill-in all the API classes as templates. My computer counted 1042 methods in the API that would need filled in. It's a huge amount of work even with a small army of volunteers.
      But there are some definite advantages to true community documentation.
      Here's the index wiki page: http://code.google.com/p/skx/wiki/ClassIndex
      If anyone is interest, I can add you to the project in order to allow editing - just shoot me a PM.
        πŸ‘
        • Chris FullmerC Offline
          Its great Jim! I've already done the entire constructionpoint class. πŸ˜„
            point1 = Geom::Point3d.new (10,0,0)
            Spaces between method name and parentheses yields warnings:
            (eval):894: warning: don't put space before argument parentheses
              Would be nice if the classes listed what class their inherit from.
                Jim
                Well fix it!
                  Eaxctly! πŸ˜„
                  I copied that example from the API and I didn't notice the extra space there.
                    I added Parent reference.
                    And condensed the steps to create the sample CPoint in the example. (I don't see the need for all the small steps that the Google API has. At least not when they are just there to create sample objects to later demonstrate the method.)
                    Also added a comment of the return value in the example. Something I have been missing in the Google API docs.
                    Agree or disagree?
                      Jim, I just noticed the label system. You had labelled the classes inherited from Drawingelement. Nice system of organising.
                        Jim
                        Yeah, it worked out nicely. I can't say I planned it that way, though!
                          I think we can do the same for Entity, Tool, and Observers. Though observers are not inherent from an Observer class, could be nice to have them labelled like that?
                          • Dan RathbunD Offline
                            Dan Rathbun
                            @thomthom said:
                            ... Though observers are not inherent from an Observer class, could be nice to have them labelled like that?
                            One of my peeves with the SU API. There should be a Sketchup::Observer common class, which could have been a subclass of the Ruby base class Observer.
                            I'm not here much anymore.
                              Jim
                              Is there a name for the classes that don't really exist other than to define an interface?
                              For example, there is no actual Tool base class in Sketchup. It's just a convention. An instance of any object can be a "Tool" if it responds_to certain instance_methods.
                                Dan Rathbun
                                @dan rathbun said:
                                I called it a "protoclass" (but not sure I used the correct term.)
                                (http://dictionary.reference.com/browse/proto)":2sb0s94w]proto- 
                                a combining form meaning β€œfirst,” β€œforemost,” β€œearliest form of,” used in the formation of compound words ...
                                  Dan Rathbun
                                  Reference, a topic at GoogleGroups:
                                  (http://groups.google.com/group/sketchupruby/tree/browse_frm/thread/6e6ead6cade3807a/440e3c753370ab23?rnum)":c5ik998j]
                                  (http://groups.google.com/group/sketchupruby/tree/browse_frm/thread/6e6ead6cade3807a/f1c8fdd8b6d98c72?rnum)":c5ik998j]2. I am sort of puzzed about what makes a tool. Is it the fact that it uses "Tool" methods?
                                  Yes it is strange. There is not a Sketchup::Tool protoclass actually defined (but there could be, and might be argued, should be.)
                                  So actually what makes a tool is that Sketchup treats an object as a tool if you call Sketchup.select_tool( object ); as up to that point Ruby and Skecthup would not know what it is supposed to be.
                                  So then, SU assumes that it 'could' have any of the standard tool callback methods. I think .activate would be considered as a required method. While the tool is active, Sketchup sends information to the object by calling the method names defined in the API.
                                  I called it a "protoclass" (but not sure I used the correct term.) IF there was a Sketchup::Tool class (and there really should be to be 'proper' OOP Ruby,) then it would called the superclass of the custom Tool subclass(es) that we write.
                                  It would NOT be a baseclass, because they are defined at the toplevel, and generic to the entire Ruby world, not just Sketchup.
                                    Dan Rathbun
                                    So...
                                    Would they then be called protoless classes ??
                                      Dan Rathbun
                                      @dan rathbun said:
                                      So...
                                      Looking through Dictionary.com (Thesaurus tab) for 'protoless' synonyms:
                                      • Concocted
                                      • Contrived
                                      • Ad lib
                                      Or perhaps:
                                      • demiclass
                                        Jim
                                        This is an html page of the SketchUp API classes. Save it as a .html file, and then bookmark it in Firefox. Edit the bookmark to open in the Sidebar. Instant API sidebar.
                                          Jim, I think you forgot the link or something
                                            Jim
                                            Hmmm, first time that's ever happened...
                                            The forum doesn't like HTML, so I uploaded it encoded.
                                            • Open it in Notepad++,
                                            • Select all
                                            • Plugins > MIME Tools > Base64 decode
                                            • Save as api_sidebar.html
                                            (same way to decode those non-rbs encrypted scripts, btw.)
                                            api_sidebar.txt
                                            • 2 / 2
