    Sketchy Physics and Ruby
    6 Posts 4 Posters 1.5k Views 4 Watching
      jblively
      Hello,
      New to Ruby and SketchyPhyics. I've looked and looked...and I can access Sketchup entities and layers and such from Ruby, but what I really want to do is be able to change parameters of the joints in 'runtime' via a web dialog. For example to adjust the min/max of a joint. Does anyone know of a example or article that talks about this.
      Also, is there a sketchyphysics API definition like the one that Sketchup has on google?
      Thanks guys for the help!!!
      Joe
      • H Offline
        hobbnob
        Ruby was never meant to work directly with sp, but if yo uwant proper advice, ask either wacov or mr.k, none of which are on this forum, but on sketchup users instead, check my signature for the address
        My WIP Thread:Here
          GoldenFrog
          @ Alex, actually, Wacov is on Sketchucation.
          You could ask him, he should know.
          Remember, great minds think alike, and fools never differ.
          • H Offline
            hobbnob
            Sure he may be a member, but that does not mean he posts, which he doesn't
            My WIP Thread:Here
              GoldenFrog
              http://forums.sketchucation.com/memberlist.php?mode=viewprofile&u=11520 He actaully has posted...493 posts. πŸ˜†
              • W Offline
                Wacov
                That I have, but it's certainly been a while πŸ˜„
                I think it's possible, just difficult. From what I've found, you generally have to change the way SP works to achieve deep-down stuff like this, so it'll either only work on your machine, or it'll have to use LazyScript (the problem is the 'runtime' part... joints are initialized at the simulation start using their set attributes). I'll look into it a little further though, it'd be a useful feature to have πŸ˜„
                SP unfortunately doesn't have an API, and I think it'd be pretty hard to understand if it did πŸ˜‰
