    HELP setting up a SU code editor
    97 Posts 11 Posters 7.9k Views 11 Watching
      driven
      @chris fullmer said:
      So when we're talking Mac compatibilty in this thread, are you mostly thinking about the apps that write the program, or are you also referring to scripts that have been written on one platform not working on the other platform? So far I have not ever run into that (that I know of). Is it common?
      Chris, your input is very helpful, please bare with the meanderings. they do tie together.
      This thread is primarily an inquiry into 'cross platform' editor compatibility
      my input is Mac'centric' because I own Mac's and whilst there are mentions of problems here and there I couldn't find an appropriate thread dealing with potential solutions.
      there is even less information for anyone trying to find a solution for those using Linux or variants
      The answer may be that there is no single solution, unless Google suddenly packages up SU Plugin development kit
      it's possible you haven't, most 'ruby' scripts are fine, unless complex. it's when you start move away from just 'ruby' that it all goes pear shaped
      You would notice more if on a Mac, there's a lot of PC only scripts.
      Martin, I hope you saw my apology, and perceive it as such. I put your absence down to workload and it hadn't occurred that I may have 'driven' you away... thanks for pointing it out jessejames...
        jessejames
        Thanks John for apologizing and i now hold a great respect for you. Anyone can make mistakes, but only the truly honorable have the capacity to admit them. Thank you!
        Always sleep with a loaded gun under your pillow!
        • chrisglasierC Offline
          chrisglasier
          ... Is it common?
          I am not really qualified to participate in this debate but my experience may be helpful in the light of Chris's comment.
          I have published two plugins - cgScenes and nset SketchupAPI and I am working on an expansion of these to provide deeper hierarchies and greater control of scenes and components, unlimited links to data from local and remote sources and analytical animation.
          These use web dialogs, which seem to me to be an important link to get Sketchup models to the general population to serve as transporters of reusable data. cgScenes works on a Mac only because of extensive work by John [driven]. The problem with the other two seems (I think) to come from conversion of data stored in JSONotation.
          So whether or not you acknowledge my approach, problems with two important parts of current technology - the web and efficient data transfer - should be recognised in relation to Sketchup, Macs and PCs.
          Incompatibility may indeed be not common. If so perhaps the reason is fear of the unknown, supported by many threads here recounting the horrors. I think John has a great and noble idea how to overcome or at least find the causes of these problems and I sincerely hope you will all work together to find the means.
          Please don't shout or shoot at me; I am only an aging reluctant (and amateur) coder.
            driven
            hi all still interested,
            I've continued pursuing a SU external editor, and currently am trying to set up http://www.jetbrains.com/ruby/features/ruby_ide.html which although not free has great potential for the sorts of things being done on SU rubies. don't let the Rails credentials put you of this an almost infinitely tunable rudy ide, and settings can be shared, so once one person has the right SU build, others could try it out, tweek it more, write plugs, sounds a bit like SU.... Very powerful in the right hands but tunable for beginners. Have a look.
            In the mean time I did a little experiment with Alex's Ruby Code Editor and I thought some might be interested,
            on a Mac in SU 7.1
            it is a live editor, not photoshop, http://getfirebug.com/firebuglite it's in beta, I've only just installed it so can't report on it's full potental
            • Dan RathbunD Offline
              Dan Rathbun
              That IS interesting John.
              But it's only for coding and testing WebDialogs (not Ruby.)
              By running in Alex's Code Editor, only Alex's Code Editor is being debugged.
              But it may have promise.
              @ThomThom: You may find this interesting, Firebug extension for jQuery development: http://firequery.binaryage.com/
              I'm not here much anymore.
                πŸ‘ πŸ‘
                Nice find!
                Hope it will eventually also work with Firebug Lite.
                  driven
                  Hi Dan,
                  I've been using it to help debug Chris Glasier's nSet for Mac use, but in the process I tried it on 3 or 4 WebDiolog
                  based rubies and it seems a very useful debug tool, for that type of interactive ruby that is popular... and usually PC only. it does report .rb errors (in relation to itself)
                  I was actually trying to put syntax highlighting into RCE using a similar approach, and though I'd try this as a practice run. I should point it to my url.local and run more features, but I haven't stopped using it long enough yet...
                  has any one tried Ruby-Mine yet??
                    Afraid not. The last week I was deep into getting to grips with C programming.
                    So much to try out - so little time. 😞
                      chrisglasier
                      This relates to FireBugLite.
                      Can anyone tell me why this happens:
                      and how to change what so I can see the code.
                        Dan Rathbun
                        @Chris: Do you have nsetWebDialog.set_full_security= true or false ??
                        (It defaults to false if you don't explicitly set it.)
                          Dan Rathbun
                          @Chris: In your webpage for nset, it would easier if you assign an ID to the SCRIPT element(s) that load the external javascript files.
                          %(#804000)[<SCRIPT ID='nset_core_js' LINK='..path../core.js'>]
                          Then in Firebug Lite, try inspecting by ID. Enter the ID name in the inspect control box. If that doesn't work, try entering:
                          document.getElementById('nset_core_js')
                            Dan Rathbun
                            Firebug page(s) to bookmark:
                            http://getfirebug.com/wiki/index.php/Main_Page
                            http://getfirebug.com/wiki/index.php/Firebug_Lite
                            Forum - Google Groups [EDIT-Added]
                            http://groups.google.com/group/firebug
                              Dan Rathbun
                              Access to restricted URI denied
                              I suspect what's happening, is MSIE copies the code into the "Temporary Internet Files" folder, which is usually a Restricted Sites Zone (security-wise.) I've tried (in the past,) to add a specific local folder to my "Trusted Sites Zone" but MSIE refuses.
                                chrisglasier
                                @dan rathbun said:
                                ... but MSIE refuses.
                                Thanks for all your suggestions, which I tried ... but as you said MSIE refuses. No FireBugLite at the end of the tunnel.
                                Thanks again.
                                  Dan Rathbun
                                  @Chris !!
                                  I think I was always trying the wrong thing! I was supposed to be adding the local folder to the LIZ ("Local Intranet Zone".)
                                  I stumbled upon this paper:
                                  http://msdn.microsoft.com/en-us/library/bb250483(v=VS.85).aspx
                                  So retry, go to Internet Options > Security (tab)
                                  Hilight "Local intranet", click the "Sites" button.
                                  On the "Local Intranet" dialog, click the "Advanced" button.
                                  See if the folder (beginning "file://") to your JS code is in the "Websites:" list, if not, add it.
                                  See if that helps FirebugLite find your JS scripts.
                                    chrisglasier
                                    Thanks Dan I will try that and let you know (I'm at GMT + 8 btw)
                                      chrisglasier
                                      Here's what I got in IE:
                                      and still access denied in FireBugLite
                                      So I don't know
                                        Chelmite
                                        I did a search on the aptana site for "sketchup" and didn't find anything.
                                        Are there any installation instructions on how to pair up aptana and sketchup?
                                        @thomthom said:
                                        That's an interesting article.
                                        You can download Aptana Studio and RadRails, but the installation process is long and complicated. Besides, if you just want a Ruby editor, downloading a 30-day evaluation version of the gigantic Aptana Studio isn't worth it.
                                        Complicated installation process? And the thing is free. http://www.aptana.org/
                                        Anyway - are you able to set breakpoints etc in SU plugin scripts and run them from Eclipse?
                                        • 5 / 5
