    The A show (post your Thea images)
    152 Posts 41 Posters 39.8k Views 41 Watching
    • N
      notareal
      I think that clipmap from png alpha will need some work-flow change. Anyway, in studio, you should be able to do it a bit faster, but I did create a example that works in with both SU2TH and Studio.
      When you work in the studio, you should keep textures>bitmaps tab open - it fastens work flow a lot, as you can drop texture directly to clipmap and so. Also one should merge layer/scatter/structure to one panel with ctrl -click. By default they are not merged as if one works with a laptop or smaller screen, part of the panel could go hidden.
      • majidM
        majid
        @tridem said:
        @majid said:
        here are some of my tries
        If these are first tries.... what can you achieve within a month Majid?? πŸ˜†
        it is not of me, it is of Thea so smart so genius πŸ˜‰, simplicity and sort of being clear, simple and powerful (as KT is) with a new innovative approach, with really realastic results. also I love the relighting system and try to post more renders, soon πŸ˜„. also I guess need 2-3 months to be fully adopted with Thea
          steelers05
          looking great guys...always love to see how well people transition to other rendering engines. Keep up the good work
          • majidM
            majid
            as a KT seeker, I first migrated to twilight (that is still very handy and fast enough) and now I guess my future woulould be the Thea, as it is fast (comparing to simillar same-level engines) simple and prepares wonderful results. here are some car renders.
            • majidM
              majid
              I like these two recent renders, I guess they have more rainy mood than before ones. specially after only 22 pass , the result is acceptable for me. I turned off the light for the second image , using Relight system. I like this option. also I like the displaced material of pavement
              displaced material
                sketchnl
                whow what a skills. Nice work. and it looks very good.
                http://www.sketchimpressions.nl
                • michaliszissiouM
                  michaliszissiou
                  These last too are great. About displacement: you have to use 16-32 bit B&W maps to have great results. This displacement from colour diffuse maps is not the best solution. Scale effects will occur...
                  • F
                    fymoro
                    Wow!!! Very impressive Majid. πŸ‘
                    http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                    • EarthMoverE
                      EarthMover
                      Really cool Majid. I like the displacement, but agree with Michalis, a 16 bit displacement map would make a big difference in precision.
                      I thought the cars were a bit dark also. Did a little lightening to this one.
                      Content Creator at Skapeup
                      • majidM
                        majid
                        Thanx mates for feedbacks, @earthmover: due to your postproed imag, I adjusted the Iso , Gamma and brightess and add 90persent of vignetting at my render, so this is a pure Thea render, biased method is used and it has been rendered at about 2 hour on my crappy machine πŸ˜„
                        pure Thea :)
                        • EarthMoverE
                          EarthMover
                          Looks great Majid, although the ground stone looks like it has a coat of shellac on top. There will always be lots less noise when you can brighten an image when rendering as opposed to in photoshop, especially in an 8-bit jpeg!
                          Does Thea export as .EXR or .HDR 32 bit? I can't remember and had to uninstall the SU2TH exporter because it's too unstable.
                          • soloS
                            There is a new SU2Th exporter available BTW.
                            http://www.thearender.com/forum/viewtopic.php?f=81&t=2161
                            • majidM
                              majid
                              I was trying to simulate a pavement after a nice rain, donno how much acceptable is the result. and yea it supports the HDR and EXR, also good news on exporter, u can use usual SU2KT or even Twiligh xml exporter instead of the usual SU2Thea πŸ˜‰
                              edit: thank you pete on your description of new exporter
                              • EarthMoverE
                                EarthMover
                                Sweet. I'm installing it now. Kudos to Tomasz. Hopefully it's fixed some crash issues. I completely understand we are still in Beta phase as well, so all of the bugs will get ironed out eventually. πŸ‘ Keep up the good work Thea team.
                                • majidM
                                  majid
                                  just palying, IBL lighting, biased rendering. a WIP. model :3dwh+editing
                                  • majidM
                                    majid
                                    same model, same lighting (minor changes) unbiased rendering
                                    • olisheaO
                                      olishea
                                      nice i like the unbiased version πŸ‘
                                      brighter car render looks much much better
                                      oli
                                      • U
                                        Ultimatez 32
                                        Hey solo maybe you can make this thread 'Post your thea render renders' or something like that. It'll be great! Anyways majid, great renders so far! I especially like that studio one.
                                        ultimatez
                                        Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
                                        • soloS
                                          Done...
                                          • T
                                            timmy16744
                                            i've been trying to get a good skin material, havent quite got it yet but here is a render of a girl i did quickly in thea, well not quickly...i let it run over night so it ran for 10 hours (about 500 passes on my mbp) πŸ˜„
                                            solo, or anyone else who uses thea, have you been able to create a realistic skin material. if so would you be able to post it? thanks
                                            • 5 / 8
