    HELP setting up a SU code editor
    97 Posts 11 Posters 13.5k Views 11 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @driven said:
      Basically, it seems suapi.rb could be the basis for a de-bugger..
      Why re-invent? Ruby has a debugger. It's part of the standard library. It makes more sense to get it working with SU embedded Ruby.
      I'm not here much anymore.
        Dan Rathbun
        @driven said:
        so what does this mean?
        It means I made a boo-boo (slappin' 'self up side the head!) 😳
        It's defined? SKSocket
          driven
          %(#FF0000)[defined SKSocket?
          Error: #<NoMethodError: (eval):894: undefined method `SKSocket?' for main:Object>
          (eval):894]
          %(#008000)[defined? SJSocket
          nil
          SKSocket.methods(false).sort.join("\n")
          add_socket_listener
          connect
          disconnect
          write]
            Dan Rathbun
            @driven said:
            SKSocket doesn't show up under XP....
            I can see it on my PC. At the console type:
            ` defined? SKSocket
            constantIf it were not defined the %(#BF0000)[defined?] keyword would return %(#BF0000)[nil]. SKSocket.methods(false).sort.join("\n")
            outputs:
            add_socket_listener
            connect
            disconnect
            write`
            EDIT: fixed typo: 'defined? SKSocket' was 'defined SKSocket?'
              driven
              Dan, trial and error got me there, anyway...
              thanks for the detailed explanation above, I had figured most of that out and was turning things 'on' and adding to the su_api.rb when I got distracted by being able to upload to 3D Warehouse from XP I'm trying to run a port scan to see how it differs between SUXP and SUMac upload path, I suspect a clash, but SU crashes if I come out of it to turn on my scanner, do you happen to know the PC routing to 3D Warehouse from SU?
              • Chris FullmerC Offline
                So in the end is it possible to hook up a debugger to SU? Pecan seemed to get something working, but his project seemed unstable on many systems. So iis possible, or not really. This painful thread is 5 pages long and its gone off on to so many tangents, I just can't take the suspense any more. Debugger possible? πŸ‘ πŸ‘Ž
                  So I thought I should post a link to Pecan's previous work. so I started digging around only to find that nearly all traces of it have been removed from the forum at his request I think. I think it worked on his system but caused so many problems for other people that he did not want to troublshoot it anymore.
                  But I did find a link to the wiki where he was updating everything. This might be itneresting to some of you guys. It seems to me like maybe you are talking about some of the same stuff that he was was trying to do to.
                  Error 404 (Not Found)!!1
                  (code.google.com)
                  See if that is helpful in any way.
                    driven
                    Chris, that's incredibly helpful, I have tried all those search terms in various combinations and never come across this before... thanks for pointing it out.
                    and yes a SU 'ruby' de-bugger is possible it's just not easy and cross platform, a little trickier still... and a multi language SU debug is a real 'bugger'
                      driven
                      @dan rathbun said:
                      Again, is Geodesic a Google plugin, or a third-party plugin?
                      Sorry Dan I do keep forgetting to add this
                      *** This code is copyright 2004 by Gavin Kistner
                      *** It is covered under the license viewable at http://phrogz.net/JS/_ReuseLicense.txt
                      *** Reuse or modification is free provided you abide by the terms of that license.
                      *** (Including the first two lines above in your source code usually satisfies the conditions.)
                      Author:: Gavin Kistner (mailto:!@phrogz.net)
                      Copyright:: Copyright (c)2004 Gavin Kistner
                      License:: See http://Phrogz.net/JS/_ReuseLicense.txt for details
                      Version:: 1.3, 2004-Oct-3
                      Full Code:: link:../Geodesic_SketchUp.rb
                      This file allows the user to add geodesic models to SketchUp (http://www.sketchup.com).
                      See the Sketchup::Geodesic.create method for more information on creating and adding a geodesic dome/sphere.
                      ====Version History
                      20040916 v1.0 Initial release; relies on Geodesic.rb
                      20040920 v1.1 Rewrite to use only SketchUp classes
                      20040920 v1.1.1 Fixed it to actually load πŸ˜‰
                      20040920 v1.2.1 Added icosahedron option. Spruce up documentation.
                      20041003 v1.3 Added primitive picker to the dialog interface. (Thanks TBD!)
                      The Sketchup::Geodesic class cannot be instantiated; it is a wrapper for the Sketchup::Geodesic.create method. See that method for more details.
                      class Sketchup::Geodesic`
                        driven
                        definitely separate, SU only uses one processor so you really want to be on the other...
                        [quote="Dan Rathbun":1k2r0bq3][
                        Hmmm.. things are getting better when things become cross-plaform.
                        I agree, although separate OS builds of common components and libraries isn't a big issue, especially if use RubyStacks or similar to output your SU versions.
                        Don't suppose you have ever watched the You Tube videos on 'MacFuse'?the last 10 minutes + Q&A of the long one are interesting, [it all is if you use mac....] http://code.google.com/p/macfuse/
                          Dan Rathbun
                          So I thought I should post a link to Pecan's previous work. (SuRDebug)
                          Oh yes.. I had actually downloaded this last December, but have yet to install and try it out.
                          As John says it's Win32 only at present, but it's based on the Wx GUIkit, which is supposed to be cross-platform. The editor is based on SciTE Scintilla, and is a bit out of date (SciTE is up over ver 2 now.)
                          The thing I didn't 'like' about it (from first blush,) was that Sketchup is run as a subprocess of the editor. I'd prefer they run in separate processes, connect by I/O pipes. But in practice it may prove not to be a big deal.
                          Scintilla is also supposed to be cross-platform (the SciTE 1.73 source code ...) STOP ..hold the presses!
                          I just checked the ver 2.01 source code of Scintilla, and it now comes with the MacOSX/Cocoa source code [the macosx dir was empty in ver 1.73, and the cocoa dir and it's framework subfolders is new.] And yes there are xcode project files. (EDIT: This is interesting, the Mac/OSX port of Scintilla was written and contributed by Adobe Systems! They needed to make the changes to support their ExtendScript Toolkit. The new code and xcode project files from Adobe were added into Scintilla ver 1.74, which is why my v1.73 folders were empty.) sourceforge link
                          I believe SciTE only has distros for Win32 and Linux/GTK+ available so far. (EDIT: The SciTE ver 2.03 page says it's been built and runs on: Windows XP, Fedora 8 and Ubuntu 7.10 with GTK+ 2.12.)
                          Hmmm.. things are getting better when things become cross-platform.
                          (EDIT: So I am thinking that SciTE, Notepad++ and SuRDebug, all based on Scintilla; could be ported to OSX.)
                            Dan Rathbun
                            πŸ˜† not processors, John.. processes
                            (At Ruby console, type Process.pid and you get the process id number.)
                              driven
                              @dan rathbun said:
                              :lol: not processors, John.. processes
                              It was late by the time I shot that off :oops:
                              More of a Freudian, typo-slip really... then complete ignorance
                              should read as... definitely separate, And as SU only uses one processor core, I really want a separate process to be on the other... but, I'm not even sure this terminology is any clearer?
                              So, I suppose what I'm trying to describe is a Separate App [bit like DashCode] that references/runs SU [on demand] when requested and also, has it's own separate openGL preview window for any other bits and bobs.... does this make sense?
                              • tbdT Offline
                                tbd
                                you know that SketchUp Bridge allows running ruby code from another process in the SU process.
                                for openGL preview you can have a window inside SU for previews (tested by myself) but depends on what you want to preview in the first place.
                                http://plugins.ro
                                  driven
                                  hi TBD,
                                  can Sketchup Bridge work on a mac?
                                  • tbdT Offline
                                    tbd
                                    driven: not yet. I am working on it.
                                    http://plugins.ro
                                      jessejames
                                      I didn't think that YOU (the author of one of the most comprehensive "hey guy's SU codings NOT hard" books proscribed to the FOFO school of teaching and learning
                                      I hadn't grasped that your, "hey guys, no need to look under the hood" API was devised to slow peoples own programing knowledge.
                                      I must say I'm rather disappointed in your attitude.
                                      Yes i must say i am rather disappointed in your low brow attempts to slander Martin. If you don't like the way Martin chooses to teach Ruby scripting, guess what, DONT READ IT!
                                      You only make yourself look like a vindictive little brat when you make comments like these and i am very upset no one else has called you out on it (mods i'm talking to you!)
                                      I think Martin takes a wise approach to teaching by allowing the student to take the course that suits them well, not by cramming certain practices down their throats and saying deal with it.
                                      This whole thread is in my option a waste of time. You need to listen more to Dan Rathburn because he is on the right track.
                                      "Google give us the power and we will build the infrastructure".
                                      Always sleep with a loaded gun under your pillow!
                                        I see nothing wrong in this thread. Good discussion that is all.
                                          One could say - if you don't like the thread - don't read it. πŸ˜’
                                            I'm desperately trying to do just that, but somehow I am compelled to keep reading in hopes that I might begin to comprehend what the thread is talking about. πŸ˜†
                                            So when we're talking Mac compatibilty in this thread, are you mostly thinking about the apps that write the program, or are you also referring to scripts that have been written on one platform not working on the other platform? So far I have not ever run into that (that I know of). Is it common?
                                            • 4 / 5
