    [problem] slider moving from fast to slow
    4 Posts 2 Posters 500 Views 2 Watching
      tomer1981
      hey.
      you must have noticed this phenomenon. when i configure a slider like this:
      getVar('something')
      it automatically gets a value of "0" (zero). during the simulation, when it gets a different value by:
      setVar('something',1)
      it reacts violently to that, and moves very fast at first, and by the time it reaches the end of it's path, it slows down. the thing that bothers me most, is the fast acceleration, since if you hold a box, for example, with a claw, or something, then the fast acceleration causes the box to fall.
      is there a way of making slider move in a constant speed? or at least, reduce the acceleration at the beginning and the deceleration at the end, without losing the overall speed of movement?
      • H Offline
        hpnisse
        Hey!
        Try to set the "damp" at least doubble of "accel", and play around with diffrent numbers.
        Hope this would help a little.
        /hpnisse
        ` /hpnisse`
        ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
          tomer1981
          hey hpnisse.
          tried that, with all kinds of different combinations. it help a bit when it concerns small distances of movement, but when you go large, it still behaves very violently...
          if only i could transform the stable rotary movement of the "motor" to a linear movement, without getting caught up with gears...
          • H Offline
            hpnisse
            Hey.
            There is a simple gear creater inside the Physics Engine.
            When you click with the "Joint Connector"-tool in one motor/hinge/slider/piston and hold Ctrl (control) -key and press a second motor/hinge/slider/piston these Joints connect to each other, a motor/hinge to a slider/piston would be a wormgear and motor/hinge to another motor/hinge would be a normaly gear.
            With this trick you don´t need that much geometry in the physics model that slow it down.
            I had attached a model with example of a motor to slider, in two ways. first, with physics geometry and a second with physics gear connecting that I explain earlier in this text:D
            Physics gears.skp
            hope this maybe would be some help.!
            /hpnisse
            ` /hpnisse`
