    Alternate API, Pioneers Wanted
    28 Posts 6 Posters 3.8k Views 6 Watching
    • chrisglasierC
      chrisglasier
      Thanks for your support, driven; I really look forward to Mac compatibility.
      So now I have mechanisms for setting and retrieving the properties of movers and boxes to be moved, the next task is to start building routes.
      Edit: Last section deleted as revised by following post
      • chrisglasierC
        chrisglasier
        Load = boxes to be moved,
        Name adds a new stage to the route.
        None for positioning movers or run empty legs.
        First - box to be moved
        Number - number to be moved, or
        Last - to be moved
        Each name is a computer object that is able to store information about itself.
        The location of all the boxes and movers are recorded at the beginning of a session.
        The process for each stage is to:
        Name it
        Select an object in SU display; move or rotate as necessary
        Select menu item to save the key and index
        Mover = Selection
        Destination adds the final position and rotation (transformation) of the mover for this step.
        Putting paths, turns and pauses aside for the moment, I think there is enough information in the model transformations and the key/index pairs to animate moves from one 3d point directly to another.
        I not quite sure how picking will work but perhaps raytesting would be a good basis. I need to look into that.
        • chrisglasierC
          chrisglasier
          Yes raytest seems to be the way forward. The idea of boxes moving seemingly out of control should be appealing to Kellyites. Can anyone offer some snippets or further ideas about this?
          • chrisglasierC
            chrisglasier
            @martinrinehart said:
            I've also finished the design of the multi-instance animator. Simple and light. Will get to it as soon as I finish YARC (yet another Ruby console).
            Any chance for SCF to have a look at the "Simple and light multi-instance animator".
              jessejames
              I've created an alternate API for moving, rotating and scaling. Design goal: eliminate the transformation matrix; let the developer move, rotate and scale directly.
              Martin,
              i like this Alternate API approach. This is exactly what i proposed some 2 years ago but at the time i was just beginning the long and weary obstacle course of learning the Ruby language. Well now i have quite a good grasp on the language (about time right!) although strangely i have picked up other languages very quickly.
              Anyhoo, i wanted to offer a suggestion for extending this API to correct some asinine inefficiencies in the BoundingBox class. Of course like you mentioned in the Movable and Transformable, these methods should belong to some derived class. But alas we can't hold our collective breaths forever lest we suffocate and die waiting for change.
              I find the need to grab a group/comp by it's "bbox.center", "bbox.center_bottom", and "bbox.center_top" so important that i wrote a nice function to encapsulate all the calls required to retrieve these points. So maybe you would like to add this, maybe not. Let me know. It would be so nice to call obj.bounds.center('center'), obj.bounds.center('top'), or obj.bounds.center('bottom'), but that will have to wait.
              @martin said:
              I'm creating SketchUp learning materials. If you want to compete with me, please write your own code. Otherwise you can use this as if it were public domain.
              And thanks for being an honest scripter who is willing to share knowledge with others free of attached binding licensing. We need many more folks who think as you do because such practices fosters innovation. Sure we could lock up some code and make a few quick buck, but then we would have sold our souls in the process. We have many honest scripters, but we always need more.
              Thanks again Martin! 😍
              Always sleep with a loaded gun under your pillow!
                jessejames
                @dan rathbun said:
                There is a plugin for this (that needs some language cleanup,) written by Sahi.
                It's called AxizComp.rb
                Thanks for the heads up Dan! Although i won't look at since my function works just fine. I try to never look at other scripts and learn my way around a problem using only the docs and my Ruby Console (God i wish we had a multi line console!!!). Copy and paste is detrimental to your future evolution as a programmer. Only in the most extreme circumstances when i feel i have exhausted every possibility of self reliance then and only then would i take a "peek" at some OS script to get an idea of how to do it.
                • chrisglasierC
                  chrisglasier
                  404 Not Found
                  (www.alexschreyer.net)
                  • Dan RathbunD
                    Dan Rathbun
                    It's called AxizComp.rb (Axis Components), see this thread (ther's some code snippets for other languages later in the thread.)
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=21635&hilit=axis#p181881
                    EDIT: With the release of SketchUp 2020, grips on object bounding boxes are now native !
                    https://help.sketchup.com/en/current-release-notes
                    I'm not here much anymore.
                    • 2 / 2
