    My Models (~goldenfrog~)
    137 Posts 14 Posters 26.2k Views 14 Watching
    • ely862meE
      ely862me
      Ely862me: What issues do you have with my car?
      This is a real car,and it s 20 years old.. u tell me what are ur car issues..
      Being given it s in your first 10 cars it s acceptable but don t take it wrong when it s criticized by average modelers . U have a lot to learn..but first of all teach ur eye to see what lines are natural and flows well..
      Elisei (sketchupper)
      Come and See EliseiDesign
      • G
        GoldenFrog
        Hi guys. My latest work:
        The headlights are fixed up. Thanks scott.  Tried to keep them low-poly.
        The controversial title is fixed :)
        Remember, great minds think alike, and fools never differ.
          ScottPara
          Better, but there is a fine line of low poly and too low poly. I think you might have went to the extreme here. The headlamps are too faceted and do not come across as round. Also, the small LED's around the main outboard lamp are too small (go back to downloading some good reference shots) and there are far too many. Look at the Audi headlamps for reference on how big LED's should roughly be. Also, remember that the whole inside of the light assembly will typically be chrome and not body color. This will help blend the whole assembly together and make to flow.
          A tip: You can NEVER have enough reference material when modeling. This is when dual monitors come in handy as you can have reference shots on one monitor while modeling on another.
          Good progress,
          Scott
          Love the fact that some HATE my avatar.....
          • G
            GoldenFrog
            So...How many segments in the light bulbs should I use? 12, perhaps? The thing is, Dave rated my model one star saying "Too big to be useful. File size is out of line for no more detail than it has.", So it's hard to keep that balance of low file size and good, detail. As for your point about reference images and 2 monitors, good news! I have a laptop so I can use its monitor for the images, and my desktop for the modeling! Yay!
              ScottPara
              Goldenfrog,
              When modeling there are a few "rules" you should keep in mind, especially when modeling "low-poly". I will get into that in a bit. I think the problem you are having now is you started this model without taking into account model size and poly count so now you are "chasing" poly counts that are already out of control.
              Some of the rules to keep in mind:
              What is the viewing distance the model will be seen from? Typically for example, furniture would be seen from about 8-10 feet. The furniture is only part of a larger scene and does not justify extreme poly counts. I model cars for Chrysler and even though our poly counts are EXTREME (80-100 million polys for a complete vehicle....NOT in sketchup) we still consider poly density. If we are doing an overall shot of the car we gut the engine compartment and most of the interior since it will not be seen in the overall image. If we are doing beauty shots of an interior, we do not have wheels or much of the exterior in the scene. If your doing a beauty shot of a headlamp then the detail needs to be concentrated in the headlamp and very little detail needs to go into much of what is not seen. So that being said, you need to start your modeling with a good understanding of what the final shots being requested by the client will be. Items like your door handle have FAR too many poly's and are just not needed. You are not doing beauty shots of the door handle right? A vehicle in sketchup can have great detail and still fall well under 10,000 poly's, probably 5,000 is more than enough. The other thing is you can accomplish many things with good texturing. You do not have to model many things that can be shown with a good quality texture.
              My advice is before you even model take some time to think about the overall composition (we storyboard every shot) and how it is going to be used and seen. Gather as much reference material as possible. Model in segments of the car. Model the body first. Get the lines and proportions correct first. Then slowly start adding detail to areas that will be in the foreground. Remember that a car is typically very symmetrical. You can model half the car, make a component of it and flip it. Now you are only modeling half the car and the other half of the component will follow.
              Hopefully this gets you started on the right track. If you have more questions please feel free to ask. We are all here to help.
              Scott
              • G
                GoldenFrog
                Scott,
                Thank you for your advice. It may do us good if you know what I'm really up to with Sketchup.
                I'm not arguing with you here. I am really using it for fun, and I'm just a teenager with no clients. If I do decide to look for a career in 3d modeling, your advice will help me very much. However, I'm thinking of something regarding chemistry, sooooo...I may not need to be too concious of my poly count. However, I have reduced the poly count of the door handle, as seen in the attachment below:
                I have also found the source of my large amout of polys, Haha...I used the "Add Detail" sandbox tool, so I could move certain points around on the mesh, but I forgot to delete the unused polys. But, in the latest revision, I have those fixed. I havent uploaded this revision yet, however. I also rounded the grille.
                ~Goldenfrog~
                The handle itself is made from a hexagon.  The curves have 3 segments.
                Grille.
                  ScottPara
                  Goldenfrog,
                  Adding detail too early on is what killed you ๐Ÿ˜„ I always start out with a very rough shape and refine it slowly, always keeping in mind where I need more detail and where I do not. I think the fact that you are going back and trying to fix certain areas and learn from the advice shows growth so I give you respect for that. I have also added a link that might help you in the design phase of your cars. We sketch everything first and then scan in our sketches to model over them. It is a great way to stay true to your original design as well as keep proportions. I hope this will help you. The tutorials are mostly photoshop training videos and such but the overall concept carries over into any program you choose to model in.
                  http://www.carbodydesign.com/tutorials/hand-drawing-sketching-tutorials.php
                  Chemistry huh? Well good luck to you.
                  Best regards,
                  Scott
                  • G
                    GoldenFrog
                    Scott
                    Thanks for the encouraging and helpful advice, and the link. I will check out the tutorials there. ๐Ÿ˜„
                    ~Goldenfrog~
                      ScottPara
                      No worries. We are all here to help. With such a diverse group and skill level I find this forum one of the best for just about any design advice.
                      Scott
                      • P
                        pixelmonkey380
                        attached is a head lamp i'm still working on.
                        projector beams, bubble covers like a mercedes a turn lights.
                        best advice would be to work with circles and pulling lines. think of wedding cakes and cones.
                        looks like you're getting the idea! keep it up!
                        chris<pixelmonkey>:D
                          ScottPara
                          Nice work Pixelmonkey.
                          Scott
                          • G
                            GoldenFrog
                            Thanks pixelmonkey. The light is looking really great. Have you finished the rest of the car?
                            • G
                              GoldenFrog
                              I fixed the scale issue...
                              • G
                                GoldenFrog
                                Hello, fellows! As the weekend passed, I was getting very inspired by Gran Turismo 5 prologue, and Gran turismo 4. So, I started work on a car a few minutes ago. So far, I'm happy with it. ๐Ÿ˜„ It is very much based on the Ford GT.
                                No new work on the Goldenfrog Motors D-180. I may get around to doing that, but not any time soon.
                                EDIT: Any comments, guys? Here's yet another new project: Nissan GTR. Pics are below.
                                In the Kerkythea render, the inside of the light is red. This will be fixed. But, for now, look at the detail in the lights. I had three referece pictures, so that helped alot.
                                I'm really please with how it's turning out! ๐Ÿ˜
                                Constructive critisism is always welcome, if you want 3d views, go here : http://sketchup.google.com/3dwarehouse/details?mid=5b102076d2e1f968f6c80f6a5291c505
                                Please post a reply! ๐Ÿ˜„
                                Beauty shot of the front.
                                The light.
                                • G
                                  GoldenFrog
                                  Chaps? ๐ŸŽ‰
                                  • soloS
                                    Headlights are a great improvement mate, however the body looks a little over smoothed/softened.
                                    • G
                                      GoldenFrog
                                      Pete,
                                      Thanks for the feedback. I had three reference images for the headlights. ๐Ÿ˜†
                                      As for the body being to softened...Does that mean I should unsoften some of the faces? Or, should I just add more polies, and smoothen it. Not sure quite what you want done.
                                      GF
                                        dmk
                                        U no my 2010 mustang gt500 that's on the warehouse that in made I'm looking to up date it so
                                        it all 2010 mustang not half 2010 hAlf 2008. Rogue is the only one with good mustang taillights and ther on his new 2011 rogue milono
                                        dmkยฎ
                                        See my models at http://sketchup.google.com/3dwarehouse/search?uq=13272125559300964517&scoring=m
                                        • G
                                          GoldenFrog
                                          Hmm...Last time I asked him if he was up to anything new, he said that he hadnt much time to do sketchuping. Is he working on this milano ro has he uploaded it? Hey, in case you need a nissan GTR based car, you could use my new nissan GTR when it's complete. ๐Ÿ˜„
                                            dmk
                                            Thanks man
                                            dmkยฎ
                                            • 2 / 7
