    The A show (post your Thea images)
    152 Posts 41 Posters 24.6k Views 41 Watching
    • soloS Offline
      Thea that is... πŸ’š http://www.thearender.com/cms/
      Some random renders while beta testing the new render engine.
      Olives, unbiased render. (image resized for posting)
      DOF (depth of field) done with rendering engine . No post processing
      http://img692.imageshack.us/img692/5876/tr2olives1000.jpg
      • soloS Offline
        http://img692.imageshack.us/img692/6383/dragonthea.jpg
        • soloS Offline
          Thea biased render 4mins 31s
          http://img692.imageshack.us/img692/9803/kettle1biased.jpg
          • N Offline
            notareal
            Great looking dragon! A bit different than the classic "Stanford" dragon seen so often.
            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
            • soloS Offline
              Thanks, I like the material, I used 'medium' to give it depth.
              This one I used displacement for the wrapping.
              http://img692.imageshack.us/img692/3695/kissesthea1000.jpg
              • FrederikF Offline
                Frederik
                Great to see such quality renders made with Thea Render... πŸ‘
                Cheers
                Kim Frederik
                • soloS Offline
                  Thanks Kim, it's an awesome engine.
                  I missed the whiskey challenge as I was unable to post due to being in beta, so rather late than never.
                  http://img692.imageshack.us/img692/8522/whisky1000.jpg
                  NO PP
                  • soloS Offline
                    Thea biased.
                    http://img692.imageshack.us/img692/1391/chutheabiased.jpg
                    http://img682.imageshack.us/img682/3809/church2theabiased.jpg
                    http://img7.imageshack.us/img7/7809/azumatheabiased.jpg
                    NO PP
                    • soloS Offline
                      Thea relight, one render only, many light options.
                      [flash=860,415:o1cojyn9]http://vimeo.com/moogaloop.swf?clip_id=9604547&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=&fullscreen=1[/flash:o1cojyn9]
                      [flash=860,415:o1cojyn9]http://vimeo.com/moogaloop.swf?clip_id=9494009&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=&fullscreen=1[/flash:o1cojyn9]
                      [flash=860,415:o1cojyn9]http://vimeo.com/moogaloop.swf?clip_id=9351407&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=&fullscreen=1[/flash:o1cojyn9]
                      • soloS Offline
                        Built in vignetting option (amount according to your preference)
                        http://img682.imageshack.us/img682/1447/vignetting1000.jpg
                        built in bloom option (amount according to your preference)
                        http://img682.imageshack.us/img682/463/testbloom1000.jpg
                          dedmin
                          I downloaded the beta - seems awesome to me and pretty fast! And very good balance between quality, speed, price, possibilities and application integration! Plugin for SketchUP and Blender, 3DS and obj import, Linux version!
                          • soloS Offline
                            ...and is available for Mac's too. πŸ’š
                            not forgetting the amazing solid exporter Tomasz created. πŸ‘
                            • pmolsonP Offline
                              pmolson
                              The only problem I detected in looking at all the images is that whoever was sitting next to that glass of whiskey was negligent and let the ice dilute what I am sure was first rate hooch.
                              Amazing renders.
                              p
                                sepo
                                Great renders Pete. I hope it is easy to use as well.
                                • soloS Offline
                                  Thanks Sid, like everything in life, if you take the time to learn it it becomes very easy.
                                  The learning curve is slightly less than Vue or vray, more than Podium and Irender, IMO just right for the results one can achieve.
                                  • olisheaO Offline
                                    olishea
                                    nice work pete. downloaded beta.....
                                    although i cant see much reason to go for thea over twilight apart from displacement, what do you think? is learning curve similar to twilight?
                                    oli
                                      sepo
                                      Sounds good....I must try it.
                                      • soloS Offline
                                        No, there are more variables, the learning curve is greater than Twilight, Twilight is very simple and powerful integrated render solution, Thea has many more options for you to tinker with, a material editor which IMO is second to none.
                                        It will take some learning to get fluent with Thea, the results and speed of Thea is worth every second spent learning it however as IMO it's one of the fastest CPU based biased and unbiased engines around.
                                        • olisheaO Offline
                                          olishea
                                          thanks for the reply pete πŸ‘ gonna give it a go
                                          oli
                                          • N Offline
                                            notareal
                                            There is Thea Render manual.pdf that comes with installation, it's good to browse trough specially when you to start to modify materials. SU2TH has a own separate manual - download that with the plugin.
                                            SU2TH plugin do save material info inside the SU scene. I think that the best work flow is to set material with the SU2TH plugin. Then, with a simple scene, there is not much else to do in Thea than hit the render button.
                                            • 1 / 8
