    Tank "Overhaul": The Panther - WIP
    23 Posts 15 Posters 2.6k Views 15 Watching
    • numbthumbN Offline
      numbthumb
      Thanks for your reply, Liam.
      Well, the turret is not rich in details, at least not at its sides. Hopefully, markings and numbers, as well as camo job could fix that. As for the weld seams, maybe it´s better not to carve them into geometry.
      Thanks again, your comments are very welcome!
      Comfortably numb...
        liam887
        yeah some good textures should sort it out, you dont want the poly count to go mental by adding stuff you can achieve with textures! Loving the treads, any shots from the front and maybe a close up on a single section of the tread when you have time t get round to it?
        VISIT MY ONLINE GALLERY
          numbthumb
          Yes, I was thinking the same thing.
          Since this is/was pretty much a free time exercise, it may take longer than I thought ( especially because of my limited texturing skills ) 😞
          I could use a good advice on achieving realistic, weathered look with textures.
          P.S. you can find the track link here, if you´re interested: http://forums.sketchucation.com/viewtopic.php?f=15&t=25487
          Comfortably numb...
          • 2 / 2
