    The Pantheon, Rome (WIP)
    53 Posts 20 Posters 10.0k Views 20 Watching
    • GaieusG
      I definitely enjoy it. Very fine details, indeed (I can imagine it takes yourtime πŸ˜‰ )
        jopsa2
        thanks for the great comments guys! I'm looking forward to finishing the modelling and start on making some renders.
        just yesterday I closed the bottom of the model, thus making the oculus and the door the only two light sources. Instantly the renders have huge amounts of noise and it's nothing I've been able to fix using the camera parameters in vray. I'm sure there's some variable that needs to be touched, but it escapes me. Any tips?
        Example:
          jopsa2
          Hello sketchucation!
          Just finished modelling recently, and started on the texturing, so I decided to bump this up again.
          I have some questions for the vray masters though! Image number 4 for example, took around 4 hours to render (at 1000x540 pixels, on my 2.4 quad core), and I'm getting worried about render time when I'm finished and want to do the final big render. What would you guys recommend without losing too much quality?
          Last of the clay renders, after this I started adding materials. Obviously lots of post-pro (Noise is intentional, I may add πŸ˜‰ )
          Halfway done with the mats!
          Material test
          Previous render, before the post-pro
          Detail
          As always, any comment/critique is welcome!
          • artysmediaA
            artysmedia
            Hey! Nice to see you again with great progress in the pantheon!
            Waiting to see what will happens next! πŸ˜„
            Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
            Blog: Artysmedia
            • david_hD
              david_h
              Critique. . . .I don't think there's enough detail here. YOu haven't shown any cracks in the Sidewalk! πŸ˜‰ πŸ’š πŸ‘
                Roger
                Hola amigo.
                El magico de processo post
                In PhotoShop I flipped the dome on a second layer so I have one facing left to right and the other right to left. I made the top layer about 50 percent transparent and then erased all but that showing in the over exposed circle of light. Then I merged the layers. That is a quick and dirty way to do it without your skp file.
                Another and perhaps better way would be to make two files. One with the sun where it is and then in the second image, move the sun by about 4 to six hours which will drastically move the bright spot. Then use these two files as I did in the first example. Put each file on a seperate photo shop layer. Make the top layer transparent to the desired degree and erase away all but the slightly darkened detail to fit in the hot spot.
                And another variation would be to create a white clay model and a gray clay model. And this time without moving the sun erase and composite the white and dark versions as already demonstrated.
                How did you make the dome? Did you create one converging panel and then rotate copy it to complete the dome? I think possibly not as the light leaks would have appeared all the way around (????). If you can get one leaf/petal of the dome perfect and then use copy rotate to place the others, there will be less opportunity to make errors and fixing errors will be quicker.
                In th same mode of thought are you making full use of layers? That model will soon be ginourmous. If you are not already doing it, use layers to their fullest advantage. Maybe put all columns on one layer, all arches on one layer, all niches on one layer. The more layers you can turn off while working on another layer the faster the work will go.
                Where do you live in Spain? I am thinking of moving to Granada. My wife and I will go this summer and look at cave houses.
                http://www.azcreative.com
                  jopsa2
                  hey artysmedia! thanks for the comment, I'm looking forward to finishing it, I can't work on it as much as I'd want to though!
                  Critique. . . .
                  haha cheers david, but if I started criticising it I'd never stop, I know exactly where all the mistakes are πŸ˜„
                  @roger said:
                  Hola amigo.
                  hey Roger! thanks for the great tip, I hadn't thought of that, I was thinking of doing two renders with different exposure times (the second one without the white burnout), but your method is definitely more efficient!
                  About the dome, the whole model is very heavily componentized, so the dome is actually made up of 28 segments, which I then joint-push-pulled. I have had problems with light filtering through, but I find it's just a question of being very careful when you join different objects together, to make sure the contact is closed.
                  Layers are definitely very important, as you say. In this model in particular I worked from the top-down, so that's how I split up the layers (Dome, frieze, windows, etc, all the way down). I'm surprised though, the model is extremely complex (25,2Mb, 10M edges), but Sketchup isn't being too problematic. I recently managed to open the file in my five year old 1.6GHz laptop, and did some orbiting around, even!
                  I'm from Madrid, but have been to Granada a couple of times. It's a beautiful place, the Alhambra in particular is breathtaking. Youre not making any mistakes if you choose to live there!
                  • P
                    pichuneke
                    But all the tourists go to live to the most touristic places, like Granada, and Spain is plenty of unknown beautiful places.
                    For example, the town where my mother was born, Almagro, in La Mancha, is touristic, but there is not a massification of tourists, like Granada. In fact there is only one japanese painter πŸ˜„
                    Sorry for the offtopic, jopsa, your work is astounding. I have some interesting links about roman archeological excavations in Spain, I can send you by PM.
                    Forgive my spanglish...
                      jopsa2
                      I agree completely, tourism is huge in spain and in some cities it has blown out of proportion, I was commenting on the city itself, which is amazing. Maybe it's because I'm not particularly fussed about tourists haha πŸ˜„
                      Offtopic is fine, I see it as a nice conversation while we wait for a vray expert that can help me out πŸ˜‰
                        jopsa2
                        at the expense of looking cocky, I'm just too proud not to post πŸ˜†
                        PS. this one took an absurd 4 hours to render, at this quality. still need help with that if anyone has any tips?
                        • david_hD
                          david_h
                          Excellent work. First rate! by all means . . .post away ! You should feel proud.
                          Even though the rest of us hate you. πŸ’š
                          • Paul RussamP
                            Paul Russam
                            Damn good work.
                            Paul Russam
                            English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                              jopsa2
                              Even though the rest of us hate you. πŸ’š [/size]
                              haha noo please don't hate! πŸ˜„ all I know about plugins and vray I know thanks to these forums, I'm very happy to share! Even though I realise these posts look like shameless self-promotion πŸ˜†
                              thanks to everyone on sketchucation!
                              • broomstickB
                                broomstick
                                @jopsa2 said:
                                Detail
                                http://forums.sketchucation.com/download/file.php?id=43297&mode=view
                                You want a comment... I'm Italian, I'm up at 8.40, I am still without my glasses, but when I saw this image I was like... "Mamma mia... Mamma mia...." (OMG... OMG...)
                                This thread should be shown to anyone who asks what you can do with Sketchup.
                                  Roger
                                  Increible y mas profundo! Sweet.
                                  The beauty is that you can listen to architecture critics and historians talk about the building, but you know it better than they because you have built it with your own hands.
                                  • C
                                    choppir
                                    mate, realy nice detail!
                                    Good work!
                                    choppir
                                      jopsa2
                                      Thanks guys, I really appreciate it!
                                      Rogeryou're right, I've learnt so much, not only about the Pantheon, but all about the Corinthian style, etc. (not to mention about Sketchup!)
                                      broomstick, thanks for the comment πŸ˜‰ it really isn't that crazy, most of the detail are displacement maps (which I made), so not that much geometry really.
                                        jopsa2
                                        I'm supposed to be studying for an exam, but, y'know, I could let the computer render while I'm reading... and once it's done, I can't not post-process it πŸ˜„ πŸ˜’
                                        I'm getting annoyed, I'm sure it's just a day or two away of being finished, I just don't have the time!
                                        This post brought to you by sheer boredom πŸ˜†
                                          is that true that rain comes inside by the occulus can't touch the ground?
                                          • P
                                            pichuneke
                                            [attachment=3:34iqcoyr]<!-- ia3 -->085.jpg<!-- ia3 -->[/attachment:34iqcoyr]
                                            In the National Geographic Magazine of History (not the usual one) of this month , appears a drawing of the Pantheon. In that drawing, all the windows have the aspect of the first photo that you have uploaded. Perhaps those two windows are the original roman ones, and the others are recent restorations (I don't know). If you want to see the magazine, don't worry, it's the spanish edition, paisano πŸ˜† πŸ˜‰
                                            (I suposse you are modeling the actual Pantheon, not the original one).
                                            • 2 / 3
