    Backface UVs - How?
    3 Posts 2 Posters 242 Views 2 Watching
      dburdick
      I see that there are some bugs in the api docs on mesh.uv_at. Can someone enlighten me on how to get the UV's of the back face? I know I can get the fronts with mesh.uv_at(3,1).x The first index is the point, the second index (1) should be the flag for front or back, yes? I've tried using true/false but no luck.
        what flags did you use when you obtained the PolygonMesh?
        Face.mesh
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#mesh
        Add these numbers together to combine flags. A value of 5 will include all flags, for example.
        This is wrong. 7 is the value if you want to include them all. It's a bitwise combination of the optional values.
          dburdick
          Face.mesh
          Thanks for that. Indeed, I was using 5 instread of 7 as the mesh flag.
          Thanks again
