    After a carve/cut plugin
    4 Posts 3 Posters 717 Views 3 Watching
      jamma-pcb
      Hi all
      Does anyone know of a plugin that can cut many components at once and delete any of the objects contents within a bounding box.
      or a better way to decribe what I'm after--- anything within the cut box is erased and the rest of what is left of the components outside the box is kept. It's like intersect/cut
      Any help here would be welcomed
        d12dozr
        Bool Tools, $10
        http://goo.gl/f7ooYh
          chrisjk
          I'm not really clear what you are after, however if Boolean difference is not it, then Zorro might answer your needs.
            jamma-pcb
            bool tools did it not bad for 10$
            With your input, this post could be even better šŸ’—
