    Grass Models Here and Free
    12 Posts 9 Posters 5.9k Views 9 Watching
    • david57D Offline
      david57
      http://3dup.com/models/index.vfx?dv=3D_Plants/Grasses_and_Weeds
        KXI System
        gotta remember that if I want to make a huge file size model. ๐Ÿ˜ฎ
        Getting the perfect sig is hard...
        Google it!
        • V Offline
          vizfellas
          thx for sharing ๐Ÿ˜‰
          STUDO Light+Designers http://www.studo.pl
            manojglobal
            I really like it, thanks for sharing ๐Ÿ˜Ž
            I'm create a house model in sketchup 7 pro but i facing some problem. Can u explain how to create grass and plant in sketchup.
            Thanks in advance
            Manoj Singh
            • Alan FraserA Offline
              Alan Fraser
              The best way of creating grass in SketchUp is to use a group of intersecting transparent png files...like these http://www.google.com/images?hl=en-GB&q=grass+png&sourceid=navclient-ff&rlz=1B3MOZA_en-GBGB328GB328&ie=UTF-8
              I don't mean by using the Intersect command in SU...just arrange them on the ground, leaning slightly at all kinds of angles and directions. All these example have under 200 faces each for the entire clump of grass, yet they look just fine when rendered.
              http://www.formfonts.com/viewModel.php?id=13435&config=1
              3D Figures
              • honoluludesktopH Offline
                honoluludesktop
                Alan, Any chance that you can provide a example of "jumbled" png files, before and after render?
                  Alan Fraser
                  Here's a very quick example...and how it renders. If I'd spent longer arranging the clones more randomly...so many of them weren't at the same height and angle, it would have looked much better.
                  grassbillboard.skp
                  3D Figures
                    honoluludesktop
                    Thanks, Got it. Did you use a plugin to distribute the components, then go back in and adjust them?
                      Alan Fraser
                      No. I just made a few, then copied and rotated them. Then kept selecting everything and copy/rotating that till I'd got enough. You only have to do that a few times to end up with a ton of them.
                      3D Figures
                      • karamouzaK Offline
                        karamouza
                        OMG Alan, I thought it was a photo of your backyard!!!
                        Wish I could do something similar with my limited imagination and skills...
                        Any chance you could make a tutorial on the subject?
                          jeabdc
                          Thailand Thankyou
                          • X Offline
                            xrok1
                            Alan, you need to model a lawn mower. ๐Ÿ˜†
                            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
