    Just finished (new)
    26 Posts 3 Posters 8.3k Views 3 Watching
      dedmin
      Thanks - very helpful for a newbie like me!! Is this what You mean for the drawer?
        dedmin
        One more - I made the drawer with the Dovetails Drawer plugin and maybe we should call the author for this "half pin" adjustment.
          That's better. Turn the grain on the drawer bottom 90Β°, and make the bevel slightly longer though. The bottom pin on the back should be a half pin and right on the bottom edge. I've got several models at home that show that. I'll see if I can post an image.
          As to the plugin, I don't think there's any need to change it. You don't want to make that change to the front ones. It would be easy enough to modify the lines from the plugin before running Push/Pull.
            I had a few minutes at lunch so I banged out this example for you.
            http://farm5.static.flickr.com/4011/4370955950_abf2f7edea.jpg
            Notice how the horizontal edge of the lowest socket on the drawer side intersects the groove for the drawer bottom.
              dedmin
              I see - thanks. I think we are talking about different plugins - the one that I used creates the whole drawer at once.
                Oh, I see. I found that plugin to be more work than just drawing the drawers by hand. I thought you were referring to the dovetail plugin I mentioned in another thread.
                  dedmin
                  I gonna check it out. I started a new project - this time in inches πŸ˜•
                    Looks like a good one. I did a similar one awhile back. It doesn't have the spindles in the rails at the ends, though.
                    http://img.photobucket.com/albums/v506/weekender410/Prairie_Settlea-1.jpg
                    • GaieusG
                      Dave you seem to have an example model "you did awhile back" for almost everything!
                      πŸ˜„
                        dedmin
                        I use this projects as way to master SketchUp and learn woodworking. In my country the MDF and melamine are all over the place - it is getting boring. And the old masters are fading away πŸ˜•
                          dedmin
                            Gai, you're right. The problem is remembering that I've already drawn them. πŸ˜„
                            Dedmin, it is unfortunate that furniture and cabinetry have gone that way. I suppose it is mostly a cost issue. It's cheaper to use "termite poop" and plastic. Unfortunately, as you say, the masters are disappearing. You should get into woodworking (real not virtual) and revive the art of woodworking there.
                            Those legs are sometimes done to get quarter sawn faces on all sides. I think there's an easier way that only requires three pieces of wood. For that matter, I prefer a couple of plain sawn faces since it is impoosible to have four quarter sawn faces naturally anyway.
                              dedmin
                              Yes - it is more manufacturable and technological! And the time - people wants everything now! But we are still waiting to see 250 years old MDF cabinet!
                              Here is a Bulgarian house from 19 century
                              http://liternet.bg/publish9/mkoeva/teoria/dom.htm
                                dedmin
                                There are 2 dovetail plugins from this guy. The second one gives you more control but it is in french only.
                                http://www.premiumwanadoo.com/technaulogis/exemple_5.php
                                  Yes, I think someone translated it, though. I have an English version of it. It puts the dovetails on the blue axis starting at the origin and outside a component even if it is open for editing.
                                  My drawing process doesn't require that I know things like the width and height of the drawers before I draw them because I draw the parts in place and draw them to fit the opening. I edit the components after they are all in place to add the joinery and other details. Drawers are never at the global origin in my models because there's always some other structure, a case or table frame which has its lower, front, left corner at the origin. That dovetail plugin isn't really a time saver for me because I would have to either move the dovetail layout it draws or copy/cut and paste it into place to modify the drawers.
                                  That's just my method of work, though. Everyone has a different way and that's what makes SketchUp so cool. You can arrive at the same point down different paths.
                                    Excellent πŸ‘
                                      dedmin
                                      Thanks. Time to start a new one β˜€
                                        How about a Windsor chair?
                                          dedmin
                                          Here we go:
                                            dedmin
                                            Yes, it's gonna be challenge!
